Too much timing, even if you dont ping?
Subscribe
Jan 13, 2006 | 01:26 PM
I have 11.1to1 compression in my stroker LT1 with 230/236 cam duration at .050, if that helps. But if you are running a dyno tune, and your motor runs great on 92/93 octane can you put 110 unleaded in and bump your timing up and gain HP/TQ. Or will it just get to be too much timing.
I also usea DELTEQ system for ignition questions to this.
Reply
Jan 13, 2006 | 02:28 PM
Re: Too much timing, even if you dont ping?
The best way is to dyno tune with the higher octane gas to select the right timing.
Reply
Jan 13, 2006 | 03:12 PM
Pretty much what the other post said. You can't generalize, you have to test.
Rich
Reply
Subscribe
