Tip in throttle is terrible and car bucks a lot
Old Sep 8, 2020 | 11:31 AM
grabbem88's Avatar
Stage3 Elliot dart pro’s ported intake 1.6’s
.583/.597 231/241 112 plus 5 adv
30lb 58mm throttle body 6spd stock gears
full hooker exhaust 11.1cr
it idles great and wot is great but taking off and cruising sucks. Iac counts is 38 and tps is .63 warmed up at idle..
should I be going after another tune or questioning the edelbrock 58mm?
what is weird. It seems I can rev by hand and sounds clean but by pedal it lags
the cable does have slack in it but don’t know how tight it should be or remember
Old Sep 8, 2020 | 12:17 PM
Re: Tip in throttle is terrible and car bucks a lot
You did a data log, and I started to take a look at it. But you explained you didn’t drive it aggressively, because “no brakes”. And you said you were getting a “touch up” tune from pcmforless, so I didn’t see any point in going further with the scan review.
https://www.camaroz28.com/forums/gen...roblem-888496/
Are your brakes working? Was a new tune installed? Are you seeing this hesitation when rapidly opening the throttle with the engine under load?. Are are you just revving it in the driveway?
Old Sep 8, 2020 | 12:50 PM
grabbem88's Avatar
got brakes working no new tune yet wanted to make sure I was telling it right. Apologize for that.
Old Sep 8, 2020 | 12:52 PM
grabbem88's Avatar
I took it easy first time got out of control
File Type: mov
Old Sep 8, 2020 | 02:25 PM
Sounds good !
Old Sep 8, 2020 | 03:24 PM
WhiteWS6's Avatar
I agree! Sounds really nice, I would think the poor driving quality is probably attributed to the tune. Or the semi-extensive mods.
Old Sep 8, 2020 | 04:12 PM
grabbem88's Avatar
thanks. It needs gears for sure. Everything is tight since it’s all been built but it’s killing me trying to drive it slow. Bucks like sum bitch
Old Sep 8, 2020 | 04:14 PM
grabbem88's Avatar
Sounds good !
thanks!
so this is what I’m thinking. Put stock back on and it drives the same it’s the tune. If it gets better. Still need some tuning but go to a 52mm?
Old Sep 9, 2020 | 02:45 PM
RUDEDOG's Avatar
It might be normal. The more horsepower the less streetable they are. Mine is not streetable enough for some people to drive. I went with 4:10 gears and it woke up.
Old Sep 9, 2020 | 02:46 PM
RUDEDOG's Avatar
You have to have a good tune!
Old Sep 9, 2020 | 04:48 PM
grabbem88's Avatar
i agree but it should rev on command sitting at idle and why does it rev fine by hand but not by pedal?? I will confirm everything this weekend hopefully.
Old Sep 26, 2020 | 07:25 PM
grabbem88's Avatar
Update:
I took 58mm off. Drilled a 11/64 hole cleaned it all up and now tip in is decent and throttle isn’t breaking up either... I can drive at 55mph in 6th with no surging or bucking...
hopefully with Solomon tune it will just get better from here.
Air-Adam
Jan 13, 2009 01:14 AM
LT1 POWR
Nov 26, 2006 08:41 PM
speed_demon24
Sep 18, 2006 12:19 PM
sno whitez
Jul 24, 2006 09:27 AM
speed_demon24
Jun 30, 2006 11:28 AM
