TPS PO123 High input.
Old Nov 26, 2006 | 05:16 PM
LT1 POWR's Avatar
I installed my new 58mm Holley Tb, slotted and adjusted the tps to .62, where it was at stock. But now at WOT I get a PO123 code which is TPS high input. I got a max of 4.88 on my scanmaster, i've read its supposed to be below 4.9, and it is, but not by very much.
So, do I need to lower the closed throttle TPS reading down to like .50 or what. This is a new TPS btw.
Also, will I need a new tune for this larger TB. My part throttle shifts are all messed up. I dont know if it has to do with the TPS code or what.
Old Nov 26, 2006 | 08:41 PM
LT1 POWR's Avatar
Alright, I got the TPS down to about 4.20 at WOT and about .62 at idle. The throttle cable was too tight and i was reaching 100% throttle with about 1/4 pedal left.
I have my idle set at about 675 in nutral and about 575 in gear. Is this about right?
What should my IAC look like, or do I even need to worry about it?
I also got the throttle to close to about 1% if I slowly let off the throttle. I got it down to 0% but then the throttle was too tight so I had to readjust it. I figure if I just give it some time, the spring will age a little and hopefully close down to 0% again, if not, i'll have to adjust a few things. Im also useing the first hole for the spring, which is the tightest. The extra hole I ended up drilling was too much and wouldnt allow the throttle to open enough, but it's alright because it looks like it was manufactured that way.
realistyc
Jul 28, 2015 07:32 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
mrwz28
Jul 8, 2015 09:11 PM
