TIP: Before installing heads...
Old Sep 8, 2005 | 06:26 PM
Steves396lt1
Guest
Posts: n/a
Before you install the cylinder heads you spent money on, I would recommend getting time certs installed in the header threads. I had to put them in my LT1 because a couple header bolt holes were a little stripped. They were not as cheap (cost wise) as heli coil, but rather cheap considering overall cost of heads.
The reason I bring this up is, I have NOT had to retorque my headers since installing the heads with the time certs done. I have stainless LT headers, and use nothing special bolts, or gaskets. I had used Earl Pressue gaskets (personal favorite) but had to use cheap o gaskets from an SLP shorty header I had laying around.
No leaks at all, and I have a quite a bit of heat cycles into it.
Old Sep 8, 2005 | 08:45 PM
lookingforwheels's Avatar
Re: TIP: Before installing heads...
I'll have to get some of those if I ever have head work done, I already have a few bolts cross-threaded.
Old Sep 8, 2005 | 09:33 PM
Alvin@pcmforless.com's Avatar
I really don't understand what everyones problem is with header bolts.. I use regular lock washers and don't have any problems at all. My headers have been on my car for 2 years now and I haven't touched the bolts since I put them in.
all this from a .13 cent lock washer
Old Sep 8, 2005 | 09:37 PM
blind527's Avatar
I just had problems starting the threads on some. I need to make sure my passenger side bolts are still tight, but I haven't touched them in about 6 months and they are fine.
Old Sep 8, 2005 | 09:57 PM
FastZinTennessee's Avatar
I bought some header bolts from autozone for $3.99, threaded them in without doing anything special and they do their job. No leaks here.
Old Sep 8, 2005 | 11:14 PM
Steves396lt1
Guest
Posts: n/a
Alvin, Some headers dontbolt up well or seal well with some gaskets. Just a quick fix, and I would hate to cross thread some heads while on. IMHO
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
