TIP: Before installing heads...
Guest
Posts: n/a
Before you install the cylinder heads you spent money on, I would recommend getting time certs installed in the header threads. I had to put them in my LT1 because a couple header bolt holes were a little stripped. They were not as cheap (cost wise) as heli coil, but rather cheap considering overall cost of heads.
The reason I bring this up is, I have NOT had to retorque my headers since installing the heads with the time certs done. I have stainless LT headers, and use nothing special bolts, or gaskets. I had used Earl Pressue gaskets (personal favorite) but had to use cheap o gaskets from an SLP shorty header I had laying around.
No leaks at all, and I have a quite a bit of heat cycles into it.
Re: TIP: Before installing heads...
I really don't understand what everyones problem is with header bolts.. I use regular lock washers and don't have any problems at all. My headers have been on my car for 2 years now and I haven't touched the bolts since I put them in.
all this from a .13 cent lock washer
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
