timing set off by a tooth?
Old Jul 27, 2004 | 03:24 PM
blkchevyz's Avatar
how bad would it run? i just stepped up from the 306 to a custom cam and its getting some strange knock retard...
i'm pretty sure its correct.
i would think you would have some piston to valve clearence problems if it was off.
Old Jul 27, 2004 | 04:02 PM
Re: timing set off by a tooth?
Depending on which direction it was off, some indications might be- idling somewhat ok, but has no power and falls on it's face under a load. Proper idle can be hard to judge with a bigger cam.
Old Jul 27, 2004 | 04:08 PM
blkchevyz's Avatar
well it seems to idle better then the 306 did, and i havent really tuned it much.
i guess theirs no way to figure out if its correct without having to actually look at the timing set?
here the post about the knock problem
http://web.camaross.com/forums/showt...96#post2331396
Old Jul 28, 2004 | 12:12 PM
blkchevyz's Avatar
well it doesnt seem as fast as the old setup... i still have some work on the tune, and who know how accurate my assometer is.
i'll probably take it to the track this weekend and see how it does.
Old Aug 2, 2004 | 08:54 AM
blkchevyz's Avatar
well somethings not right, i'm 2 mph slower.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
