timing set crank gear?
Old Jul 14, 2004 | 08:27 PM
96birdlt1's Avatar
Is there a trick to get the timing gear back on the crank? I have the LT4 extreme duty timing set and I have the notch and the key lined up properly. Any help would be awesome.
thanks
Joe
Old Jul 14, 2004 | 09:06 PM
Line it up and tap it back on until it is flush.
Old Jul 14, 2004 | 10:19 PM
944v8inDFW's Avatar
my personal trick is heat it up on a hot plate and it will usually slide right on. I hate to beat on gears. Oh just so you wont end up in the emergency room and your lawyer calls me.... Be sure to wear protective hand garments when handling the hot gear. Those of you under 18 should not try this at home nor try it with laces in your shoes.
Old Jul 14, 2004 | 10:28 PM
atljar's Avatar
A large socket or piece of pipe has always worked for me
Old Jul 14, 2004 | 10:37 PM
96birdlt1's Avatar
I tried the large socket and it seems to get hung up maybe a half an inch from flush and dosen't go further. I am whacking it pretty good, but I am afraid to hit it too hard and mess something up.
Will heating it up damage it in any way, such as weaken the teeth or anything?
Joe
Old Jul 14, 2004 | 10:40 PM
atljar's Avatar
No heating the gear will just expand it a little. Actually, if allowed to cool slowly, it may even strengthen the metal.
Old Jul 14, 2004 | 10:43 PM
96birdlt1's Avatar
Cool, I will try it tomorrow.
Joe
Queens94z28
Dec 20, 2014 09:11 PM
ModdedNerd
Dec 18, 2014 10:52 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
