timing gears
Old Feb 17, 2007 | 10:26 PM
maro z28's Avatar
timing gears
What has gears that are turned by the timing chain besides cam and crank? There was a post regarding using stock water pump gears for a certain timing set. I thought only the cam and crank were connected by the timing chain, covered, with pulleys on the outside. The serpentine belt connected to these pulleys and to pulleys for your water pump, ac, alternator, etc...Some explanation please. LT1 specific to be more specific. Thanks!
Old Feb 17, 2007 | 10:41 PM
Confusing..... an LT1 engine specific questions.... but its on "General....."????
The water pump is driven by a gear off the timing set, not by the belt.
Moving.............
Old Feb 18, 2007 | 06:13 PM
maro z28's Avatar
So, can anyone post up a pic of a timing chain on w/out cover on. I thought it only went around the cam and crank sprockets???
Old Feb 18, 2007 | 06:18 PM
jay_lt4's Avatar
the chain still only goes around the crank gear and cam sprocket,, but there is a gear around the back side of the cam gear that runs a shaft above the cam gear,,, this shaft is supported by a bearing in the block and runs through the timing cover to spin the water pump
Old Feb 18, 2007 | 06:23 PM
2000GTP's Avatar
http://shbox.com/ci/sprockets.jpg
http://shbox.com/ci/front_cover.jpg
Old Feb 18, 2007 | 06:40 PM
maro z28's Avatar
What connects the shaft to the gear that runs it(the one on the back side of the cam gear)?
Old Feb 19, 2007 | 12:05 AM
Good reading for an LT1 owner:
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Feb 19, 2007 | 07:27 AM
maro z28's Avatar
Thanks, now I see.
ChrisFrez
Dec 15, 2014 03:09 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
