Timing Gear Set
Old Aug 16, 2008 | 03:53 PM
GMH94Z28's Avatar
Timing Gear Set
I am in the middle of my cam install and realized that I ordered the wrong timing gear set. I ordered a cloyes -3039 and it doesn’t have the optispark splines in the middle like my stock gear has. I called summit and they don’t show a set for a 1994. Does anyone know of a good stock or better replacement? Autozone has one but I have never heard of the brand before. It looks like the stock one. http://www.autozone.com/R,89679/vehi...ductDetail.htm Where is a good place to order gm parts that dont rape you on shipping? Thanks again
Old Aug 16, 2008 | 11:51 PM
GMH94Z28's Avatar
Does anyone know if this one will work for a 94? It says 93. I keep seeing mixed answers.
http://store.summitracing.com/partde...4&autoview=sku
Old Aug 17, 2008 | 08:22 AM
Kory 88 Iroc Lt-1's Avatar
93 and 94 are the same as far as the timing chain is concerned. They both use a non vented opti. The summit chain will work. Stay away from the autozone chain.
Kory
Old Aug 17, 2008 | 09:04 AM
96capricemgr's Avatar
The confusion stems from the fact the 94 F-bodies and Vettes use the unvented but the 94 b-bodies and d-body(fleetwood) use the vented, the catalogue companies can not seem to grasp this simple thing so they struggle to help you get the right parts for a 94 of any model.
Everybody wants to assume the stocker is somehow bad, it's not, it works great. If you want a different one though I thnnk if you look up a 93 on Summit it will list a Lunati timing set.
Old Aug 17, 2008 | 10:19 AM
GMH94Z28's Avatar
Does anyone know what is up with the lunati timing set? It looks like a gm stock gear in the pics. Thanks for the info
Old Aug 17, 2008 | 12:40 PM
Aside from the multiple keyways on the crank gear, I believe it is. I'd just buy a stock set. You don't need the added keyways.
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
