Alternator/voltage regulator issue???
Old Aug 16, 2008 | 10:26 PM
ricehammer's Avatar
The car - 96Z28, H/C/LT's/True Duals.
The problem - The volt meter in the gauge cluster drops to ~11V and the check gauges light starts flickering (which it's supposed to) when I'm on the gas, accelerating or just maintaining speed. If the engine is idling, the volt meter sits at 13V. I'm pretty sure that it's not the battery since it's new.
I've had alt's die before in other cars, but never with these symptoms. What's your take?? Anyone seen this before??
Old Aug 17, 2008 | 02:57 PM
ricehammer's Avatar
Neeever mind. It's the alt and I didn't even have to remove it and have it tested. I went to remove the bat cable from the back of the alt and discovered that the post the cable is connected to was loose in the alt.
z28cam1993
May 29, 2015 10:17 PM
z28cam1993
May 20, 2015 10:27 PM
armedtrigger
Feb 24, 2015 08:30 PM
BlowBye
3rd Gen / L98 Engine Tech
24
Jul 22, 2002 07:56 AM
