Timing gear for '95
Old Jul 5, 2006 | 04:57 PM
football4life's Avatar
Timing gear for '95
where is a good place to buy a timing gear that will fit my z
Old Jul 5, 2006 | 05:00 PM
seawolf06's Avatar
Re: Timing gear for '95
Depends if you just want a stock gear, LT4 heavy duty or a double roller like the cloyes 3145. I have my stock set if you want it. For the double roller, you'll have to get an electric waterpump. Do some searching and you'll find what you're looking for. Welcome to the site.
Old Jul 5, 2006 | 05:04 PM
i need a stock gear for a lt1 thanks i have found this site pretty cool
Old Jul 5, 2006 | 05:05 PM
seawolf06's Avatar
Try the junkyard first, should have plenty there. If you wanna buy mine, pm me.
Old Jul 5, 2006 | 05:09 PM
one more Question i purchased a timing gear from jegs but it doesn't have the water pump gear on the back if i were to buy an electric water pump would i be able to use my new gear
Old Jul 5, 2006 | 05:11 PM
seawolf06's Avatar
Yes you would. You don't need that wp drive gear if you have an electric waterpump. Which one did you get? Make sure it lines up correctly.
Old Jul 5, 2006 | 05:23 PM
it is a blue racer and my dad bought it thinking it would fit but when it got to my house it wasnt the same i dont know about how well it would line up the chains have a differnt thickness would that cause ne problems
Old Jul 5, 2006 | 05:30 PM
seawolf06's Avatar
If it's part number 270-WG805, then it probably won't work since it says it's for big block chevys. If you have the stock LT1, then it's a small block. If you're working on the car anyways, most people would suggest upgrading the timing set to a double roller and installing an electric waterpump anyways. The chain will be more reliable and the wp will net you about 10 rwhp and should keep you cooler in traffic.
Old Jul 5, 2006 | 05:33 PM
Ok hey thanks alot
ChrisFrez
Dec 15, 2014 03:09 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
