timing dot question
Old Feb 28, 2006 | 12:01 AM
T/A Racer's Avatar
timing dot question
dumb question but just checking something are the timing dots supposed to be right beside eachother or like cam at 6 oclock and crank at 12. or both at 12o clock with dots almost touching vertically. thanks
Old Feb 28, 2006 | 12:25 AM
CamaroBoy96Z28's Avatar
Re: timing dot question
Cam 6, crank 12 at #1/6 TDC. I think the dowel is at 3 or so. Shoebox has a picture on his tech page.
Old Feb 28, 2006 | 12:32 AM
1racerdude's Avatar
12 & 6 or 12 & 12 both are correct. One is firing on #6 one is firing on#1.
Old Feb 28, 2006 | 07:39 AM
Exactly.
12 & 6 = #6 TDC
12 & 12 = #1 TDC
Old Feb 28, 2006 | 07:41 AM
Javier97Z28's Avatar
Moderator
Probably easier to eyeball 12/6 correctly though
Old Mar 1, 2006 | 07:04 PM
bodydroppeddually's Avatar
if you did it 12 and 6 do you have to change anything? what is the difference between 12 and 12/ 12 to 6?
Old Mar 1, 2006 | 07:09 PM
Z95m6's Avatar
The reason you can have it be at 12/6 or 12/12 is because the cam spins at half the speed of the crank. There is no difference its just a different cylinder is at top dead center.
Old Mar 1, 2006 | 07:20 PM
would you have to change the firing order?
Old Mar 1, 2006 | 07:45 PM
Not sure what you are getting at. Both are in the normal sequence of the cam/crank timing, so there is nothing to have to change.
Old Mar 1, 2006 | 07:48 PM
Dave89IROC's Avatar
actually, both are TDC, one is on the compression stroke, one is on exhast
Old Mar 1, 2006 | 07:57 PM
Z95m6's Avatar
Yeah you're correct i don't know what i was thinking.
Old Mar 1, 2006 | 10:15 PM
Most people relate TDC to the compression stroke. Technically, TDC is TDC whether on the compression or exhaust stroke. The piston is still at the same place. It's the cam that is in a different position.
Feffman
Oct 9, 2015 05:42 AM
Ken Cemo
Jan 27, 2015 08:45 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Noenav
Dec 6, 2014 07:35 PM
Jul 4, 2005 05:00 PM
