Timing Chain set up for N20/Boost?
Old Feb 25, 2006 | 12:01 PM
  #16
playa7970's Avatar
Re: Timing Chain set up for N20/Boost?
=)sdscacac
Old Feb 25, 2006 | 12:12 PM
  #17
Demon's Camaro's Avatar
Not to keep carrying this off topic but the stock LT1s are governed at 155.
Old Feb 25, 2006 | 03:28 PM
  #18
Camaro_Guru16NY's Avatar
Whats everybodys opinion on the gear drives when compared to a regular timing chain?
-john
Old Feb 25, 2006 | 09:47 PM
  #19
HardcoreRM125's Avatar
Demon's Camaro : No, Thier not. There is not top speed limiter if your car has Z-Rated tires from the factory/150 speedo. Top speed on a bone stock LT1 F-Body is over 150 btw.
Old Feb 25, 2006 | 09:49 PM
  #20
To do a gear drive, you have to have a tuner disable your knock sensor completely.
It picks up all the extra noise as knock, and retards the timing/makes it run like ****. Its not worth the hassle in tuning to switch to gears.
What does have to be done to convert to a Cloyes double roller? Besdies and E-WP?
Old Feb 25, 2006 | 09:52 PM
  #21
Loadre's Avatar
I'm running a stock chain on my setup.
Old Feb 25, 2006 | 10:03 PM
  #22
Loadre's Avatar
Originally Posted by RedLT4Mike
I chose to run a Pro Gear single roller that required
no clearancing to the timing cover, in combonation
with a CSR electric water pump.
The stock chain is a bad joke when laid next to the
pro gear roller.
Where did you get this from? Price? Part number?
Old Feb 27, 2006 | 11:42 AM
  #23
I was just curious as to their longevity and reliability. Im looking at running one in my BBC here shortly and could give two hoots about the knock sensor and the ECM for that matter. Gotta love carbs.
-john
Old Feb 27, 2006 | 12:52 PM
  #24
Now that you've got things off topic... let's at least post the correct info.
If your LT1 left the factory with the "base" tires, your top speed is limited by the stock programming to about 115mph (the exact number varies by year). If your car left the factory with the optional (RPO "QLC") Z-rated tires, the number entered in the top speed limiter field in the stock PCM programming is "255". That's the largest number you can put in an 8-bit binary field.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
