Time for a cam....I don't know jack about cams
Old Feb 25, 2007 | 07:12 PM
KillerTA's Avatar
Alright, it's time for a cam swap this spring but I don't know which cam to get. I've done searches on this board and others but everyone has a different opinion so I'll give you the details of what I want.
1) I don't want to rev the engine much past 6000rpm. I need it to last for100,000 miles at least, and don't race the car anyways.
2) I do most of my driving at low to midrange rpms
3) I realy want that lopey muscle car sound--like an old GTO or something. Is it possible to keep the lower powerband and still get that sound?
4) I don't drive the car much so diveability isn't overly important. It's just a fun weekend car.
What do you think?
Old Feb 25, 2007 | 07:49 PM
Z95m6's Avatar
For an off the shelf grind I'd go with the XE224/230. My buddy has it and its a damn good cam for what you want. Your wants are very similar to mine except for the lope thing. I just go a custom cam from BRE thats supposed to do just all that. I just got it installed but i'm gonna break it in before i hit the gas and see what it can do.
Old Feb 25, 2007 | 08:10 PM
snakeatinZ's Avatar
Another vote for the CC503. get it with a 112 lsa if you like the lope.
Steve
Old Feb 25, 2007 | 08:16 PM
speed_demon24's Avatar
You don't have to break in hydrolic roller camshafts.
Old Feb 25, 2007 | 08:20 PM
Z95m6's Avatar
Yeah i understand tha,t but it makes me feel more comfortable to let it "break in" before i hammer it. I want to drive it for a little bit then change the oil. Then I'll hit it hard. It also helps me keep my sanity. I know if i got done doing the cam swap and i run it hard and it spins a bearing immediately i might go on a rampage. Now if i baby it for a while and i break it later, i might have the patients to fix it. :P
Old Feb 25, 2007 | 08:35 PM
Critter's Avatar
cc305 ftw great cam
Old Feb 26, 2007 | 02:02 AM
theratdude64's Avatar
A while ago I test drive a 95 with a cc305 and i LOVED the sound of that cam
Old Feb 26, 2007 | 02:14 AM
SStrokerAce's Avatar
You don't have to break in a roller cam.... just go beat on it.
Checking the oil is a good idea, make sure that your swap didn't introduce anything into the motor.
Bret
Old Feb 26, 2007 | 08:43 AM
AdioSS's Avatar
West South Central Moderator
To me it sounds like you want a stock cam with new springs and higher ratio rockers. That'll do everything you want. To get a decent lope just set the idle RPM much lower than stock.
If you do get a cam, I would keep intake duration under 220@.050 and run a very tight LSA.
Old Feb 26, 2007 | 09:08 AM
SS MPSTR's Avatar
CC305 or hotcam get my vote for your intended usage.
Old Feb 26, 2007 | 09:15 AM
Dave 96TA's Avatar
Just pull a plug wire off.
Old Feb 26, 2007 | 07:13 PM
Fast_Toys's Avatar
CC305 is a great all around cam. Give us a call at 204-955-4896 and we would be happy to discuss your application and give you some advice.
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
chuyz28
Nov 25, 2014 11:14 PM
