Throwing a few codes quick question
Old Oct 1, 2011 | 05:01 PM
Camaro350z28's Avatar
Hooked up the car to my laptop to pull the codes for the SES light. pulled 24, 32, and 34.. i did reset them to see what pops back up i just got the car.. but can one cause the other? where would be a good place to start? clean the egr?
Old Oct 1, 2011 | 07:20 PM
Re: Throwing a few codes quick question
DTC 24 = Vehicle Speed Sensor (VSS) circuit output speed low (this code may have set first, since it will not set if DTC 34 is set). Is your speedometer wokring normally?
DTC 32 = EGR Circulation. The PCM cycled the EGR valve, and didn't see the expected change in manifold absolute pressure (MAP). This code also will not set if DTC 34 is set.
DTC 34 = MAP circuit voltage low = high vacuum. The code sets when MAP drops below 16kPa, which is a vacuum level the engine can not achieve exceprt under very heavy closed throttle decel.
As you can see, 32 and 34 may be related.
I'm using the 94 factory manual code sheets. There may be slight differences on the 95.
Old Oct 1, 2011 | 08:45 PM
speedo works perfect. actually just tested it next to my other car on the freeway today. maybe ill replace or try to clean my egr and see if they pop back up after i reset them
Old Oct 2, 2011 | 07:25 AM
With a manual trans the code will set if the VSS signal is very low for 6 seconds, when the engine is over 1,250 RPM, the throttle is less than 1% and MAP is between 11 = 21kPa. That would indicate a moving vehicle in coast mode.
Again, this code has a link to the MAP. I would focus on the MAP first. The harness connector seems to dry out and start to crumble, causing intermittent contact. The MAP sensor can be checked with a volt meter.
Old Oct 2, 2011 | 12:52 PM
thanks man, ill try that out and see if these codes pop back up. thanks man youre always in on my questions. appreciate the help youre full of info
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
Jazsun
Dec 29, 2014 12:14 PM
