No oil pressure.
Old Sep 22, 2011 | 04:12 PM
LT1 POWR's Avatar
No oil pressure.
So I started up the new motor and I'm not showing any oil pressure on the stock gauge (don't know if that's a communication problem or not) and no oil is coming from the pushrods, so I'm assuming I'm not getting any oil pressure. I've got a canton 242t oil pan and a melling high volume oil pump and about 6.5 quarts of oil in it. It's showing full on the Lokar dipstick. For the oil pump drive I've got a MSD like this.
I've got an oil feed and return for the turbo. Is there something simple I'm overlooking? I'm running the 24X coil on plug ignition and have the oil pressure sensor connected.
Old Sep 22, 2011 | 04:42 PM
raroz28's Avatar
Re: No oil pressure.
it's all mechanical so if it's bolted on the problem maybe with the gauge.
Pot a mechanical gauge on and see what happens
Old Sep 22, 2011 | 10:44 PM
LT1 POWR's Avatar
So I took the oil feed line for the turbo off and its pumping oil to the turbo. I am still seeing no oil at the pushrods though. I packed the oil pump with assembly lube when I installed it a few months ago. I'm stumped. I have cranked it enough to where I should be getting oil. How long does it usually take to get pressure on a new build?
Old Sep 23, 2011 | 04:36 AM
RamAir95TA's Avatar
Took my build about 4 or 5 minutes to get oil to the pushrods. Unfortunately most people think that oil should be gushing out of them. Truthfully you only get a trickle..and I DO mean trickle, like maybe a drop every 10 seconds or more. If you don't look close enough you won't see it. Remember you're trying to fill all of the oil passages, pump up the lifters, and fill the pushrods which are all empty - it takes awhile.
Old Sep 23, 2011 | 11:57 AM
LT1 POWR's Avatar
I'm going to try this oil pump prime tool that O'reileys has to rent, it uses compressed air to blow out the system, then I'm putting a new oil pressure sender on. Hopefully that will solve my problem.
We cranked the hell out of it and didn't see a single drop at the push rods, so I don't know if that assembly lube that I packed the oil pump with is clogging the system or whats going on. I know it won't be gushing out, but as much as we turned the motor over, I should have seen a little oil.
Old Sep 25, 2011 | 09:12 PM
LT1 POWR's Avatar
I found the problem. Turns out I was getting oil pressure all along. I thought I was since everything is gear driven and has a very low probability of failure but that slight chance had me scared. The problem was the instrument panel connector became dislodged somewhere along the way and none of the gauges or lights were working. I'm getting a solid 55psi at start up now. And finally saw some oil spurts at the pushrods when I upped the revs a little.
Old Sep 25, 2011 | 10:02 PM
As Joe said, it takes a while. That's why you pour oil over your valvetrain before new engine startup.
Old Sep 25, 2011 | 10:56 PM
LT1 POWR's Avatar
I poured it on the drivers side valve train and into the lifter valley but didn't start it right away. On a side note, is it safe to run a mechanical oil gauge inside the passenger compartment? I got a good deal on a set of autometer gauges and could use a more accurate oil pressure gauge.
Old Sep 25, 2011 | 11:52 PM
97WS6SCharged's Avatar
Oil is fine. Worst case scenario it leaks and gets oil on the interior (it will puddle, not spray). For the price though it's hard to beat the electric gauges.
Old Sep 26, 2011 | 06:41 AM
RamAir95TA's Avatar
Any time you run fluid through the firewall, IMO, is a bad idea!
Old Sep 27, 2011 | 01:47 PM
RealQuick's Avatar
Any pics of the engine bay?
Old Sep 27, 2011 | 03:45 PM
LT1 POWR's Avatar
Still working on it. I'm trying to figure out some stuff. I'll let you know when I get it all done though.
Old Oct 2, 2011 | 02:25 PM
Originally Posted by LT1 POWR
.......On a side note, is it safe to run a mechanical oil gauge inside the passenger compartment? I got a good deal on a set of autometer gauges and could use a more accurate oil pressure gauge......
Oil is not considered "hazardous", and is not prohibited inside the passenger compartment. I've got a mechanical oil pressure gauge, and a -3AN braided S/S line that runs from the block tap above the oil filter, through the hole in the firewall that used to have the clutch master mounted through it (and is now otherwise sealed) and up to the oil pressure gauge in one of the three center dash vent holes.
Nitrous pressure gauge is similar. OK to run into the passenger compartment, as long at the connection outside the firewall is fitted with a flow restriction orifice to prevent a high flow into the interior, that would create an opaque cloud that would impede driver vision.
My fuel pressure gauge is electrical, but I did try using the AutoMeter high pressure isolator to use a mechanical gauge inside the passenger compartment, and the isolator failed, and was recalled by AutoMeter. They gave me full credit for my mechanical guage, isolator and braided SS hoses toward an electronic gauge.
GT what?
Jul 14, 2015 10:17 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
