throwing codes w/ the LTs and rubbing steering knuckle
Old Apr 26, 2004 | 01:16 PM
ppmz28's Avatar
Well, I love my pacesetter longtubes....awesome power!!! But everytime I turn my steering wheel deep it rubs the steering knuckle!!! annoying noise thats it....... what does people do to get over this. Also, I am throwing a code everynow and then! I put brand new plugs and wires on during this and the car just got a new opti last year. Yesterday for the first time I noticed a diff. when the SES light came on for a few minutes. the car bogged down like it wasn't getting any gas. I am going to get it checked....where can I go??? I really don't feel like paying 25$ to a garage to put it on the diagnostic, does any places do it for free.? thanks guys
Old Apr 26, 2004 | 01:33 PM
Cmr0z28's Avatar
Autozone.
Try bolting the shaft on the BOTTOM most point....the hole is long and oval, put the bolt through and slide it down as far as it will go, then tighten it.
Old Apr 26, 2004 | 03:40 PM
LWillmann's Avatar
Take a look and see if maybe the motormount is worn, allowing the header primary to be too close to the steering shaft.
If lifting the motor a little would make it stop, then maybe you should replace the motor mounts.
I don't know if Autozone can or will do OBDI cars or not.
Old Apr 26, 2004 | 03:45 PM
PooHoopy's Avatar
I have the same problem, go to Checkers and rent a code reader. It will read the code for you and they will give you a print out of what it is. AutoZone has to have some special OBDI guy to check it out but Checkers, Kragers or Shucks would work. It is probably the Knock modue that is making your timing off and becaue of the extra noise. My car is having the same problem and i found out that was it!
Old Apr 27, 2004 | 07:50 AM
ppmz28's Avatar
well, I have a lt4 KM and my computer is tuned for LT headers. I don't know of checkers or any of those other places. I guess I have to go to a garage to get it done thanks
Old Apr 27, 2004 | 11:03 AM
ppmz28's Avatar
alright,, I have some feedback... it's says my left oxygen sensor is bad.... it is running at about 451 and the right one hits about 655!!! So I am replacing it today...... also are these good IAC and TPS numbers??........iac-21 and tps-.60
thanks guys
Victor Lamb
Aug 26, 2017 02:52 PM
Drtryder
Apr 22, 2015 04:17 PM
Gtpguy
Jan 26, 2015 04:50 PM
91Bird305
Aug 5, 2002 01:39 PM
