Throttle response not as crisp when warm?
Old Feb 7, 2015 | 11:55 AM
94Form's Avatar
Hey guys just a quick question on if it is normal for the throttle response to not be as crisp once warm. On a cold start if I tap the throttle a bit (no I'm not revving the crap out of it, just raising rpm around 500) it responds like a sports bike. Just real quick and sharp. Once warm however, I don't want to say it lags, because there isn't really any lag in the response, but it just isn't as "crisp". Is this normal or is this some kind of pcm issue? If needed I could take a video… Thanks
Old Feb 7, 2015 | 12:10 PM
Re: Throttle response not as crisp when warm?
It runs a lot richer when cold. so you might notice a slight difference.
Old Feb 7, 2015 | 12:15 PM
94Form's Avatar
Alright good to hear! Thanks for the response and everything you've done for the F-body community shoebox!
Old Feb 7, 2015 | 05:53 PM
Data log using Scan9495 allows us to look for possible problems when it warms up and goes into closed loop.
Old Feb 8, 2015 | 05:49 PM
94Form's Avatar
Injuneer - thanks for the reply… I am completely out of my element when it comes to data logging. Are there specific sensors you recommend I look at in the data? And what would the acceptable ranges be for those sensors? Thanks again
Old Feb 9, 2015 | 07:01 AM
maybe2fast's Avatar
do the throttle-body bypass if not done already
O2s lazy?
MAF dirty?
really need a scan like Injuneer stated
Old Feb 9, 2015 | 10:05 AM
Apparently you didn't understand my post. Go to the "sticky" for Scan9495 on the "Computer Diagnostics and Programming" forum. Download the software (free). Buy a cable to connect a laptop to the ALDL connector - instructions in the thread. The scanning program records everything that it needs - you don't have to tell it what sensors, etc. After you record the data log you post it on an FTP site so we can download it, or e-mail the file to one of us. Any problem with the software - GaryDoug wrote it, so he can help you make it work,
You don't have to know the acceptable ranges... we know that, and we use our knowledge to look for problems in the data. If you would really like to know more about the data and how to interpret it, I have a 20+ page guide that I can send (.pdf).
Old Feb 10, 2015 | 12:05 AM
94Form's Avatar
Ah perfect! I will definitely try to get a scan today or tomorrow so I can post it up. Thanks again guys, I really appreciate the help
Old Feb 10, 2015 | 07:29 PM
94Form's Avatar
I couldn't get the other program to work, but I did scan it using data master. You'll have to excuse my ignorance if the scan is too long or not what you were looking for. Its about 10 minutes of idle from cold start. Entered closed loop, and at the end of the scan I raised RPMs in case you needed that too.
http://www.mediafire.com/download/js...h_acel_eng.uni
Thanks in advance guys.
Old Feb 10, 2015 | 10:29 PM
Without even looking at it, there's probably not a lot to be learned from 10 minutes of idle. Your concern seemed to be throttle response. You need to log it on the road, duplicating the driving that produces what you feel is unsatisfactory response to advancing throttle.
I'll take a look at it. I would prefer you export the Datamaster file in .csv format. I analyze these using Excel, and now I have to do the export. Scan9495 is a lot easier to work with, and produces more comprehensive data.
Old Feb 10, 2015 | 11:23 PM
94Form's Avatar
Thanks again for the response Injuneer, I might have to try this again once spring rolls around then. I'm up in MN so not really possible to drive right now Appreciate your help!
Cam's maro
Mar 24, 2015 08:09 PM
edman
Mar 13, 2015 09:39 PM
Ricardo
Nov 29, 2014 10:58 AM
BadAndy743
Jun 23, 2002 11:53 PM
Ivo
Jun 13, 2002 08:41 PM
