throttle body bypass
Old Feb 16, 2003 | 11:09 PM
cals400ex's Avatar
i know this has been discussed many times but i just want to make sure i am doing it right. it will be done on a 95z. remove both coolant lines from throttle body. attach coolant line from radiator to metal hose on passenger side of engine. then use 3/8 inch vacuum caps on both sides of throttle body. bleed system and your done. i think this is correct, but just making sure. thanks
Old Feb 16, 2003 | 11:14 PM
blazzinbird's Avatar
just for your duble check, click here
Old Feb 16, 2003 | 11:15 PM
Robbie's Avatar
Yep thats all right. But one thing I done to where I could use all the stock parts was just connect the hose from the radiator to the metal line on the passenger side intake manifold with stock tube clip. Just toss away the small 3in hose that was on it.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
May 1, 2015 11:30 AM
RedLineRev
Jan 23, 2003 03:51 PM
