throttle body bypass
i know this has been discussed many times but i just want to make sure i am doing it right. it will be done on a 95z. remove both coolant lines from throttle body. attach coolant line from radiator to metal hose on passenger side of engine. then use 3/8 inch vacuum caps on both sides of throttle body. bleed system and your done. i think this is correct, but just making sure. thanks
Yep thats all right. But one thing I done to where I could use all the stock parts was just connect the hose from the radiator to the metal line on the passenger side intake manifold with stock tube clip. Just toss away the small 3in hose that was on it.
