Thinking of changing cam..110LSA?
Old May 7, 2003 | 10:26 PM
GigaMp3z's Avatar
Are there any cams for the lt1 that has a 110lsa, other than a custom grind. The GM ASA cam for the ls1 sounds wicked, and runs wicked and the specs are 226/236 .525/.525 110LSA.
How much does a custom grind cost? I already have the 1.6rr's in my car now along with lt4 springs (which will need to be swapped)
What cam is good for me.. What lift would I need to get ground into the cam to get around .530-.540 or so with 1.6rr's?
Anyone know the powerband on an 236/240 .530/.530 110LSA cam?
-Corey
Old May 8, 2003 | 12:05 AM
Dr.Mudge's Avatar
Dont compare LS1 cams to LT1, the attempt is futile. Of course there are 110º and lower than that, anything you want.
Old May 8, 2003 | 04:23 AM
Fastbird93's Avatar
With a 110 LSA, I think it's pretty safe to say that you won't pass emissions though.
Old May 8, 2003 | 06:20 AM
GigaMp3z's Avatar
emissions? whats that?
so does anyone know the powerband on the cam above on stock heads?
thanks,
corey
Old May 8, 2003 | 09:10 AM
Xscream's Avatar
You do relize that this is the LT1 forum and ASA cars run LS1's - right?
Old May 8, 2003 | 09:06 PM
GigaMp3z's Avatar
I had no clue about any of that? come on what kind of a statement was that? I know this is an lt1 forum and as I said above it is a ls1 cam.
Im just trying to compare the two..anyone have any input or run a similar cam? My friend runs the asa in his ls1 and it peaks about 6,200 and pulls flat to about 6,600. Lots of power throughout.
-Corey
Old May 9, 2003 | 12:41 PM
Dr.Mudge's Avatar
The problem is the cam profiles are nothing alike. The cam you mention would have a pretty good lope to it though if you put it on an LT1 car. There is a similar grind I'm aware of, a 225/234 but its on a 112, you'd have to request a 110 grind, no biggy though.
However I ran a larger cam and didn't have that much lope at all, it sounded almost depressingly mild, but it made good numbers. This leaves me rather convinced that some folks dont have optimized timing, and/or fuel. With open headers though it should sound quite nice.
Old May 9, 2003 | 06:20 PM
GigaMp3z's Avatar
how much extra would it be to get the cam ground on a 110..who makes it and what are the lift #'s?
thanks,
Corey
Old May 9, 2003 | 06:29 PM
Dr.Mudge's Avatar
http://www.iskycams.com/engine_templ...7&engine_id=25
http://www.iskycams.com/timingchart....ber=211272/282
Give 'em a call.
Old May 9, 2003 | 06:30 PM
elista's Avatar
1.6's will add around 30" of lift so if your looking for about a 540" lift with 1.6's then get a cam with about a 510" lift. a lot of people also think that roller rockers will change duration but they dont they just make the valve open faster.
Old May 9, 2003 | 10:41 PM
Got-LT1's Avatar
If it opens faster and higher, than isn't it open longer?
I read they change duration by 1-2 degrees max.
BTW how do you like that B&M?
Old May 10, 2003 | 12:33 AM
96LT14u2Nv's Avatar
closest to the specs u want would be the Crane 230/236 cam. it is what i am running and has a 110 lsa,that 110 really makes it sound wicked!!!!!
Old May 10, 2003 | 10:09 AM
GigaMp3z's Avatar
Where did you get it from? Thanks for the reply.
Originally posted by Got-LT1 BTW how do you like that B&M?
I like it alot. 3rd gear is just straight up because the springs pushing it over to the neutral position have ALOT of spring. So basically when ur smashing gears just push straight up with an open palm and it slides over automatically. It scares me because sometimes it feels like im going to hit first, but it doesn't.
-Corey
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
armedtrigger
Feb 24, 2015 08:30 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
