Think I found my problem
Old Mar 12, 2012 | 09:38 PM
Macs95LT1's Avatar
Been having idle issue. Just pulled off TB to examine IAC. Everything was clean, however I took the IAC and plugged it in while holding it in my hand. Had the wife turn key to on position, could feel the IAC motor running, but the spindle just barely moved. It might have moved a 1/16 of an inch if that. Tried this three times with the same result. What do ya think .......Bad IAC?
Old Mar 12, 2012 | 09:54 PM
Re: Think I found my problem
it would be hard to know what movement equates to a "step" or "count" (perhaps there is a reference somewhere that says?). I would not consider that conclusive evidence, unless you compared it to a known good IAC. Plus, you would have to be watching what value was commanded by the computer to even know how much it was told to move.
Old Mar 13, 2012 | 09:45 PM
my1994z28's Avatar
The IAC barely as any movement,even on a new one...Did you check your air inlet elbow for rips,tares,holes???..Now that you have removed the TB,I would install a new gasket..Did you check all your vacuum lines for cracks,rips,tares??
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
jcamaro95lt1
Jan 24, 2015 08:21 AM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
HuJass
18
Jun 24, 2002 09:19 PM
