They DO exist!! (MSD Opti)
Old Jul 23, 2006 | 05:11 PM
  #46
Ponyhntr's Avatar
Re: They DO exist!! (MSD Opti)
Originally Posted by seawolf06
Did you ever figure out how to adjust the timing, in other words, which way retards it and which way advances it? Mine was not two turns out when I got it, it was only one. It's very easy to adjust with everything on and the engine running, just use a long extension, U-joint and 1/2" socket.
Mine is 2 turns out. According to MSD, turning it in is supposed to advance the timing.
Old Jul 23, 2006 | 05:23 PM
  #47
96arcticwhite's Avatar
Regarding the timing adjustment, it's almost as if the guys who desgined it weren't aware of the large number of LT1 owners that have custom programming. Also, wouldn't any adjustment be compensated for in the PCM?
Old Jul 23, 2006 | 10:06 PM
  #48
Ponyhntr's Avatar
No, because it's a mechanical adjustment. The computer doesn't know where the distributer is set. The only way you can tell if it changes when you adjust it is if you have a timing pointer on the engine and actually shoot it with a dial-back timing light.
Old Jul 24, 2006 | 09:05 AM
  #49
z2894droptop's Avatar
So.....does that mean if we have a custom tune that it will not affect it unless we mess with the screw?
Old Jul 24, 2006 | 09:55 AM
  #50
Ponyhntr's Avatar
Yep!
Old Jul 24, 2006 | 10:03 AM
  #51
Dave '97 Z28 M6's Avatar
That would save you from constantly re-flashing the PCM if you wanted to run race gas and more timing at the track, but pump gas and conservative timing on the street.
Old Jul 24, 2006 | 01:42 PM
  #52
seawolf06's Avatar
Originally Posted by SweetZRag
I called MSD and they told me that Counter Clockwise (out) is advance. The instructions also said that the Opti is shipped set to the factory settings which is 2 turns out. Mine was only set to 3/4 turn out. The MSD rep also told me that you should have about 2 turns in or out from the initial factory setting. I could only go 3/4 turn in and about 1.5 tunrns out so the turn range is not quite as large as they say. I can't say about the actual number of degrees of timing because I don't have timing marks.
Jeff
I haven't checked the range on mine, but it definitely wasn't 2 turns out when I installed it. The second quote is from another thread here which sounds more correct.
Old Jul 24, 2006 | 01:53 PM
  #53
turbo_Z's Avatar
Good luck with that. I wanna know how a guy can change the timing w/o pulling the opti out. Flashing a PCM only takes 3 minutes compared what it would take to mechanically advance the timing.
Old Jul 24, 2006 | 02:06 PM
  #54
moparman's Avatar
The MSD opti has a provision for varying the timing without removing it.
Old Jul 24, 2006 | 08:27 PM
  #55
1FstFormulaV8's Avatar
*SIGH* I wanna see one for us 93 guys.
Old Jul 24, 2006 | 08:51 PM
  #56
anaik's Avatar
http://www.msdignition.com/2006/06-4.htm
Old Jul 24, 2006 | 08:54 PM
  #57
zero231's Avatar
I'm a '93' guy and mine runs damn fine...in the wet too.
Now if only my rear-end worked this well...I'd be out cruisin'.
Old Jul 25, 2006 | 01:17 AM
  #58
As has been stated, the MSD unit provides for timing adjustments on-car. It looks like it would be a bit of a pain to get at the adjusting screw, but not impossible. And with the number of people on this board that have fried their PCM during a re-flash... I'm sure some people would prefer to use the MSD adjustment to switch from "street" to "track", especially if they were doing this on a regular basis. Plus, the MSD doesn't require a laptop/cable to adjust timing. I think the timing adjustment is a feature some people might use.
Old Jul 25, 2006 | 09:31 AM
  #59
OneFlyn95z28's Avatar
Guys. The real use for the timing adjustment is when you mechanicly advance the cam shaft. you can then dail the opti in where it belongs. back in the day alot of testing was done by some of the big tuners and they always came up with a few more HP if the opti was dailed in with the crank instead of tring to be fixed in the programing
That for us will be the biggest use of the dail. basicly a set it and forget it dail
Xiantyl
Jul 21, 2015 05:42 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
