They DO exist!! (MSD Opti)
Old May 22, 2006 | 01:07 PM
Ponyhntr's Avatar
Got it today directly from MSD. Will have some results up soon!
Old May 22, 2006 | 01:14 PM
thesoundandthefury's Avatar
Re: They DO exist!! (MSD Opti)
Nice piece. I'm toying with the idea of buying one of these and removing the cap and rotor and welding an aluminum cover over the optical half to use it as a bulletproof/leakproof cam sensor for the Delteq setup I'm running.
Old May 22, 2006 | 01:25 PM
jamilz28's Avatar
why is it better then stock?
Old May 22, 2006 | 02:32 PM
KWIK WS6's Avatar
From: Southern California, where do YOU live mutha****a?
how much?
Old May 22, 2006 | 02:39 PM
Ponyhntr's Avatar
http://www.msdignition.com/2006/06-4.htm
Hopefully they will be more reliable, and water-resistant.
Old May 22, 2006 | 02:41 PM
Ponyhntr's Avatar
Originally Posted by KWIK WS6
how much?
I believe they retail for $499 from Summit.
Old May 22, 2006 | 04:16 PM
Colin91Z's Avatar
Where is the timing adjustment on it?
Old May 22, 2006 | 04:24 PM
Ponyhntr's Avatar
It's the screw next to where the harness comes out.
Old May 22, 2006 | 04:29 PM
hotrod18_69's Avatar
Very nice.. Let us know how it works after ya get it on..
Old May 22, 2006 | 04:45 PM
Colin91Z's Avatar
Thanks I thought that was probably it, but I wasn't sure.
Looks like it might be in a spot that will make on-car adjustments difficult
Old May 22, 2006 | 06:47 PM
RCF925's Avatar
So am I right in assuming the MSD Opti for a 94 Z28 comes with Vacuum lines? If so I may buy one.
Old May 22, 2006 | 07:27 PM
Ponyhntr's Avatar
Originally Posted by Taintedz28
quick question, is the opti from MSD water-proof like dynotechs?
Yes, it is. The cap is sealed to the body with an o-ring.
Old May 22, 2006 | 07:28 PM
Ponyhntr's Avatar
According to my instruction sheet, they do come with the vacuum lines.
Old May 22, 2006 | 07:53 PM
chevy94c's Avatar
Let us know how it works out?
Old May 22, 2006 | 07:56 PM
Birdie2000's Avatar
These are supposed to take higher RPMs better right?
