Are these dyno numbers low?
Old Sep 16, 2009 | 09:38 AM
  #16
meissen's Avatar
It's a little low for spec - my LT1 gets ~47.5-49 PSI with key on, car off. At WOT my FP goes up to 50psi. While I don't know if it's 100% the pump at fault - it does seem like it's consistently lower in all your tests than it should be...
Old Sep 16, 2009 | 11:21 AM
  #17
96ZRDR's Avatar
The dyno sheet is useless without AFR results. It is all speculation without them.
Old Sep 16, 2009 | 12:22 PM
  #18
meissen's Avatar
True that - the guy who did my dyno runs immediately diagnosed the fuel pump when he saw the AFR linearly going up as the RPMs went up. Got a pressure gauge on it and sure enough - WOT the pressure dropped to 20psi.
Old Sep 16, 2009 | 12:56 PM
  #19
RobsWS6's Avatar
Your printout was STD and not SAE. Have them do SAE and see what you get, then you'll be able to see if you low or not. Also FP should be 43psi.
Old Sep 17, 2009 | 02:53 PM
  #20
ChevalierSS's Avatar
i've got a very similar setup as yours put down 340/350
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
racecarz28
Mar 30, 2015 09:55 PM
Roadie
Feb 16, 2015 10:34 AM
YellowT/A
Aug 7, 2002 12:30 PM
Joe Brodman
Jul 24, 2002 05:24 AM
