thermostat
Old Apr 28, 2006 | 08:03 AM
bodydroppeddually's Avatar
thermostat
can i run my car without a thermostat?
Old Apr 28, 2006 | 09:00 AM
teke184's Avatar
Re: thermostat
can you?
YES
should you?
NO
why do you think you need to? if it's overheating pulling the stat is a bandaid for a real problem...and can easily hide more problems.
a stat is there for a reason
Old Apr 28, 2006 | 09:50 AM
Re: thermostat
i have a new water pump and a new stat. the fans kick on but the car still gets hot. the antifreeze is staying in the engine. i think that i got a bad stat. i was going to remove the stat b/c i don't drive the car much.
Old Apr 28, 2006 | 09:25 PM
Seifer48's Avatar
Re: thermostat
you don't seem to understand that a stat allows a certain amount of coolant into your engine thus allowing you to not waste all that coolant and to not put too much strain on the waterpump which that will eventually break.
Old Apr 28, 2006 | 09:37 PM
km9v's Avatar
Re: thermostat
Replace w/ fail safe type stat.
Old Apr 29, 2006 | 09:45 AM
Re: thermostat
First time I've ever heard that one..... the t'stat blocks water flow from the radiator to let the engine warm up faster, then it opens and does not much else. It will start to close if the coolant temp drops below the desired value, to keep the engine from running too cool.
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
