Thermostat ?
Old Jun 1, 2003 | 09:09 PM
JOE96Z28SS's Avatar
Thermostat ?
I know A Lot of people buy the 160 Stat, I was thinkin bout totally removing it. I know this has probably come up before, But hell Lets discuss it again
Old Jun 1, 2003 | 09:28 PM
jeff1586's Avatar
mine is removed with a fan switch and it warms up to operating temp with noproblem and stays below the 185 temp with the fans on. It runs great!
Old Jun 1, 2003 | 09:38 PM
Scooter95's Avatar
Don't remove it. The LT1 thermostat works diffrently than a regular sbc thermo. It allowes coolant to recirculate through the engine during warm up. It's not really a good idea to run without a thermostat on any street car. A properly operating thermostat will not cause an engine to run hot. Its main function is to allow the engine to reach it's operating temp as soon as possible, thus cutting down on wear.
dis3as3d's Avatar
I think that 160 is too low and that 180 is just fine. If the coolant does not let the oil get up to temperature then it does not get hot enough to evaporate all of the water that forms in the oil from condensation in the crank case.
Old Jun 2, 2003 | 12:31 AM
JOE96Z28SS's Avatar
My engine runs at about 190 so I probably will leave it alone. Just put stock thermostat back in when I rebuilt it
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
