Is there a such a thing as cam surge in sd lt1’s
Old Dec 14, 2020 | 01:13 PM
  #46
grabbem88's Avatar
Re: Is there a such a thing as cam surge in sd lt1’s
Originally Posted by ULTM8Z
The other thing to try is to put in those voltage offsets I showed earlier. I remember when my offsets were incorrect, no amount of tuning could get the car to behave properly. When I got the correct ones finally, I could tell immediately on start up that it was right (it just felt and sounded spot on). After that, dialing in the tune was very easy.
Maybe it's a similar situation here?
Keep an eye on the WB O2 gauge though and don't nail the throttle right away... ensure your AFR's are good (not too lean) before laying into it.
those voltage offsets correct? Both tuners have totally different numbers
my afr are no less than 11.8 and no more than 15.1
Old Dec 14, 2020 | 02:03 PM
  #47
ULTM8Z's Avatar
Like I said, they come from a different Bosch p/n, but seemingly from the same family of Bosch EV1 injector. So I'm hoping they're close enough, as was the case on the Bosch-III's I've dealt with in the past.
According to the bin you sent me, your tuners didn't touch that table... and are using the stock GM values, which are particular to the stock (Rochestor?) injectors. Generally when you change injectors, to be the most correct, you should get the factory offset values from the injector manufacturer. It could be that they're close enough or (as was the case in my experience) they could be way off.
Old Dec 14, 2020 | 02:24 PM
  #48
grabbem88's Avatar
I punched those numbers in dec and all but when saved they rounded up. So is that ok?
Old Dec 14, 2020 | 02:26 PM
  #49
ULTM8Z's Avatar
That's fine. The values are in microseconds.
Old Dec 14, 2020 | 02:43 PM
  #50
grabbem88's Avatar
Ok good.
Old Dec 14, 2020 | 03:19 PM
  #51
Originally Posted by grabbem88
moe Bailey? Yeah he told me no..he doesn’t do my car???
on the injectors thing I helped put them and take them out so the injectors are Ford 30lb
400hp is nothing for 30lb so not sure why I need bigger???
My bad.... I lose track of the vehicle specifics, or don’t pay attention. He doesn’t do “chips”. Whom did you deal with at pcmforless? Alvin was the chip guy, but he now has his own business as PCM of North Carolina. I may have told you that before too.
Old Dec 14, 2020 | 03:39 PM
  #52
grabbem88's Avatar
It’s fine bud....
thing is. I burn my own chips. So not sure why he can’t help... I’m using tunerPro and make my own files as well. So not sure why he can’t make a file and send it to me?
Old Dec 14, 2020 | 04:19 PM
  #53
We're getting off topic, but.....
Injectors are sized based on FLYWHEEL HP. With your 365 at the rear wheels, you are making 420-425 HP at the flywheel, through the T56. That's converted based on actual measured losses (chassis dyno vs. engine dyno) through my original T56 at HP levels ranging from 490 to 765 at the flywheel.
Put that 425 HP number in the overly conservative online injector sizing calculators (BSFC = 0.50 #/Hr/HP, 80% max duty cycle) and you get 33.2 #/HR. If the Bosch injectors you have are rated at the Ford typical 2.7 Bar (not all Bosch are rated at that pressure) they are only flowing 31.3 #/Hr at 3 Bar/43.5 PSI.
My guideline, which I've offered to people for many years is to multiply flywheel HP by 0.07 to get MINIMUM recommended injector size. That reflects a less conservative BSFC of 0.476 #/Hr/HP, and allows the duty cycle to reach 85%. 425 x 0.07 = 29.8 #/HR. Your at the ragged edge. What happens on a day the air is colder, the barometric pressure is higher, the humidity is lower than the dyno operator used to correct the dyno HP to SAE or STD conditions. You could run out of fuel.
There isn’t a lot of downside in going to a moderately “oversize” injector. You just have to be sure the program has the correct flow rates and offsets. Too big and the PCM drivers may not be able to turn the pulse width down low enough for a smooth idle. But the 94-97 PCM seems to be able to handle 42 #/Hr with no problems at idle. Don’t know about the 93. ECM.
Old Dec 14, 2020 | 05:46 PM
  #54
grabbem88's Avatar
well after cleaning up this tune 11.2 to now 12.8 at wot I might of gained a few hp but I guess I can look into a set of 36-38 lb injectors
Old Dec 14, 2020 | 06:35 PM
  #55
ULTM8Z's Avatar
Are you saying the injector offsets helped? that would be great news!
Though if you end buying new injectors, post up before you do. We need to ensure the ones you're getting have manufacturer data available for them. Otherwise you could end up in the same boat.
Old Dec 14, 2020 | 07:36 PM
  #56
grabbem88's Avatar
no not yet but I’m confident that your offset numbers are right after doing my own research. Actually I think Solomon did have them right (bin file I’m using is actually the pcmforless)
I’m keeping the 30lb for now. My mustang back in the day made more than this lt1 (302)sorry and had 30’s and drove perfect cam was a .666/.691 246/258 at 110. Turned that thing
To 7500 but let’s not get into that.
I just wanna learn all I can and tune so I can pass it on cause face it after us motor guys it getting slim.
Old Dec 14, 2020 | 07:45 PM
  #57
grabbem88's Avatar
I also think I screwed up the o2 swing. Thinking I needed to raise it but if o2 is saying it sees it to be lean so I should have lowered the swing to computer it’s ok to be lean????
Old Dec 14, 2020 | 08:35 PM
  #58
ULTM8Z's Avatar
I believe so. Basically you're telling it not to add so much extra fuel because "it's supposed to be that way" due to the cam overlap. You kinda have to try it both ways probably and see which one gets you the results you want.
Old Dec 15, 2020 | 11:52 AM
  #59
grabbem88's Avatar
so I put the offset and only change and it cleared up this surge but now I’m rich everywhere lol
Old Dec 15, 2020 | 11:57 AM
  #60
ULTM8Z's Avatar
Did you reset your VE tables back to stock?
