Is there adjustment that can be made in the rack?
Old May 2, 2003 | 01:15 PM
JAFO1994's Avatar
I found a procedure to adjust steering rack bearing preload. Is this an adjustment to adjust play in the rack? I have 1/2" of play in my rack. I verified this after installing a rag joint eliminator and checking tie rod ends and such. The play is coming from the rack.
It's not bad, just not perfect.
Old May 2, 2003 | 01:52 PM
Yes, that is what it is for.
Old May 2, 2003 | 02:04 PM
JAFO1994's Avatar
Thanks, again
Old May 20, 2003 | 02:48 PM
Acct 23749's Avatar
how did you do the rag joint eleminator?
i assume your talking about the fabric vibration whatever thing on the steering shaft near the headers? i have a ton of play coming fron there. just jamed some screwws in there but like to do it more prefssionally
Old May 20, 2003 | 03:32 PM
JAFO1994's Avatar
You can order an aluminum spacer from www.unbalancedengineering.com for $30 and it gives you directions on how to do it. Fairly simple, you'll need a vice and hand grinder. You take that joint arm off, one bolt on top and one on the bottom by the rack. Takes an hour.
Victor Lamb
Aug 26, 2017 02:52 PM
96SilverRam
Nov 20, 2016 11:19 AM
Jun 6, 2015 08:27 AM
grgguy
17
Feb 23, 2015 07:57 PM
Joes96z
Dec 13, 2014 07:48 PM
