testing compression
Old May 23, 2005 | 05:28 PM
Fbody1's Avatar
Question testing compression
can i take out the injector fuses to stop fuel squriting from out of the injectors? or do i have to take the fuel pump plug loose? can i take the coil wire off to stop the ignition while testing the compression?
Old May 23, 2005 | 05:39 PM
sw89lt1's Avatar
Re: testing compression
just take the coil wire off the coil
Old May 23, 2005 | 05:41 PM
Fbody1's Avatar
what do i do about the fuel?
Old May 23, 2005 | 06:19 PM
Pull the PCM IGN fuse. It will kill fire and fuel.
Old May 23, 2005 | 08:11 PM
ZMAN Z28's Avatar
I just did a compression test 2 weekends ago and only pulled the coil wire to keep the car from starting. Remove all the plugs so it spins easier, less wear and tear on ur starter. Most will prob say to turn it over 4-5 times to get a descent check. I only cranked it over twice, and they were all between 155-167. I am happy with those numbers.
Z
KYWes
Jun 14, 2022 06:52 AM
Quickss96
Jan 29, 2016 05:56 PM
cmsmith
Sep 14, 2015 09:25 PM
karpetcm
Aug 14, 2015 03:02 PM
13qtr
Jul 19, 2015 05:30 PM
