Tercell losing 2quarts of oil a week , but no oil leaks ?
Guest
Posts: n/a
losing 2 quarts
don't waste your time on a compression test. A leak down test will tell you the same thing but also tells you where the problem is coming from. If you hear the air in the intake, the intake valve is the problem. If you hear it in the exhaust and if you hear it in the oil breather and so on you know the story.
Been there, done that. It's valve seals, trust me. I've got a '93 Terc and it did exactly the same thing. Everyone thought it was the rings but it wasn't. The valve seals are really sh**ty on these cars.
Depending on the year, you will need a special wrench to remove the head. It's called a "double allen" socket or something...
check out this site before you do anything. looks like toyota is having some design problems. http://www.yotarepair.com/Sludge_Zone.html
Magenta_Hearts
Mar 25, 2015 10:24 AM
ChrisFrez
Feb 22, 2015 08:47 AM
Sandersen511
Jan 13, 2015 03:49 PM
