Temperature Gauge has flat lined....
Old Jun 28, 2005 | 12:52 AM
CColtManM's Avatar
Question Temperature Gauge has flat lined....
I noticed today my temp gauge has flat lined. It doesn't move when i start up my car, or turn on the battery. What is the procedure to find out whats wrong, and get it back working?
Old Jun 28, 2005 | 12:56 AM
Black1995Z's Avatar
Re: Temperature Gauge has flat lined....
First, check the drivers side head and see its its plugged in and clean...
... I was working on my car and accidentally broke it once.
It did the same exact thing.
Old Jun 28, 2005 | 08:25 AM
Remove the connector from the sensor in the head and ground it. That should peg your gauge and prove that the wiring is ok.
Old Jun 28, 2005 | 12:31 PM
CColtManM's Avatar
Exclamation Re: Temperature Gauge has flat lined....
Slow down you guys, when you say head, what do you mean?
Old Jun 28, 2005 | 01:31 PM
jsetzer's Avatar
Clicky
Pic on master Shoebox's site, if he doesn't mind the direct link.
Old Jun 28, 2005 | 03:23 PM
ky1967stang's Avatar
lol mine doesnt move at all either but i know why....i wired up my dual fans to stay on constantly when started. atleast i know it wont run hot.
Old Jun 28, 2005 | 03:24 PM
Old Jun 28, 2005 | 03:55 PM
jsetzer's Avatar
^^^^ needs to share some garge space with the rest of it. Too many cars, too much money.
Old Jun 28, 2005 | 09:27 PM
CColtManM's Avatar
Unhappy Re: Temperature Gauge has flat lined....
My sensor was pulled out. Looks like the gray piece on the head, that the sensor clips into, broke off. So, now i have two of those metal pieces sticking out. I plugged in the sensor and Gorrilla Glued it, but i know the heat will rip it apart. Any ideas?
Old Jun 29, 2005 | 12:02 AM
jsetzer's Avatar
My pastic is ripped off the sensor also. I bent the pins out a little bit and put the plug over it. Been that way for thousandsof miles. (Bent the pins so it fits snug)
Old Jun 29, 2005 | 01:16 AM
Black1995Z's Avatar
Ha! Thats how I "fixed" mine LOL
Old Jun 29, 2005 | 11:45 AM
CColtManM's Avatar
Talking Re: Temperature Gauge has flat lined....
Well, when the Gorrilia glue gives out, which i know it will, i'll have to do that same procedure! haha
Old Jun 29, 2005 | 01:51 PM
InsuranceGuy's Avatar
I wouldn't even mess with a broken temp sensor when you
can buy new ones for $15 at O'reilly Auto Parts. About a
2 minute job replacing it.
Emil:93Z,383,Vortech,NOS
Old Jun 29, 2005 | 03:50 PM
1996TA's Avatar
My thoughts exactly. I just replaced mine the other night, $11.98 at AutoZone and took about 5 minutes.
Old Jun 30, 2005 | 11:00 AM
CColtManM's Avatar
Question Re: Temperature Gauge has flat lined....
Hmm, well, when the gorrilla glue gives out, i will look at autozone. They have the grayed piece that gets stuck to the head; that you snap into? How do you get it to stick there?
Henson071
Dec 30, 2015 09:55 PM
malikot02SS
Aug 15, 2015 01:11 PM
4586
Jul 31, 2015 06:03 PM
detroitmuscle
Jul 31, 2015 04:21 AM
colts0455
Jul 24, 2015 04:51 PM
