temp Sensors ????
Old Dec 21, 2007 | 03:25 PM
93camarochrisz28's Avatar
Question temp Sensors ????
i got a after market temp gauge.what i want to know is where do i put the Sensors end of it ?
Old Dec 21, 2007 | 03:43 PM
ricehammer's Avatar
In the drivers side head where the temp sending unit for the dash gauge is (between the 1 and 3 plugs). Pull the sending unit and replace it with your new gauge sensor.
Old Dec 21, 2007 | 03:54 PM
am i able to tap in to it if i go and get the auto meter one with the wire and not have my temp on the dash not work
i have a sunpro my buddy gave me now is it any good?
Old Dec 22, 2007 | 10:52 AM
JP95ZM6's Avatar
If you are saying you want a new temp gage to work, and still keep the stock one as well, then there is an identical hole in the pass. head - pull the threaded plug out and put your new sensor in that head. You will have stock reading DS head, and new reading Pass head.
Old Dec 22, 2007 | 11:41 AM
ricehammer's Avatar
Good call . I was wonder if there is clearance enough to get to it around the exhaust manifold. That plug can also be a real PITA to get out.
Old Dec 22, 2007 | 11:43 AM
windsma's Avatar
Nope ,
Passenger side between the 6 and 8 cly. i had to use a AN fitting to make it work.
that way u keep your factory temp gauge.
We are talking about coolant temp right?
SUNPRO SUCK , just my opinion If your going to go to all that trouble, spent 40-60 on a good one,
I have a autometer prolite w/ the AN fitting that i would sell for $60 shipped.
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
JurisAg02
Jul 27, 2002 11:49 AM
