Smells rich but runs lean?
Old Dec 21, 2007 | 04:05 PM
69gto96z's Avatar
My car seems to be running real rich. It smells rich and bogs down, so today i changed the plugs, and they all showed signs of running lean. They were very white. The car isnt throwing any codes. I installed my cc306 and had a mail order tune done from MadZ28. Anyone ahve any ideas as to what it may be doing?
Old Dec 21, 2007 | 04:26 PM
96' Formula WS6's Avatar
Have you recently done your 02's or do you have a scanner so that you can show everyone what they are reading.
Old Dec 21, 2007 | 04:56 PM
69gto96z's Avatar
Yes, I do have a scanner. I will get some readings.
Old Dec 21, 2007 | 06:18 PM
69gto96z's Avatar
Both front 02's are constantly switching back back and forth between the range of .220 to .445. I had the rear 02's deleted.
Old Dec 21, 2007 | 07:17 PM
Daniel6718's Avatar
show us pics of the plugs ryan....id like to make sure your readingh them right...the white part i nthe center has nothig to do with it...its the ring that goes around it all the same part that is the threads its how much carbon is on that and the color of it tells you what kinda a/f you have
Old Dec 21, 2007 | 09:23 PM
FASTFATBOY's Avatar
When I went to Ed Wrights to be chassis tuned, he told me about cars smelling rich but are actually lean....like mine was before he started tuning. A lean car has a different smell than a rich car.ALthough they are similar smells, a lean car will burn your eyes where a rich car will not.
DO not run it anymore. Find the problem. At idle the o2's should be around 800 ish
David
Old Dec 21, 2007 | 09:40 PM
Daniel6718's Avatar
at idle o2 should fluctuate between 200-900 or so rapidly
Old Dec 22, 2007 | 07:51 AM
As noted above, if they are really staying that low, either the sensors are faulty, or the engine is actually running lean. If it is running lean, the PCM should be trying to correct it by adding fuel. If its a "real" lean, it will correct. If its a "false" lean, its going to run rich.
What did you measure the O2 voltages with? Problem is, they are changing so rapidly (~9 times per second) you can't see all the readings, unless you are data logging with a scan rate of 10 frames per second. Then you should see the readings covering the full range of 0xx-9xx mVolts, with an average value of 450mV.
Do you have a cat?
Old Dec 22, 2007 | 09:30 AM
69gto96z's Avatar
I used my scanner to read them. Its just a code scanner that will let me view the data from the sensors/computer. And no I have no cats on the car.
Old Dec 22, 2007 | 11:55 AM
texas94z's Avatar
damn ryan. i thought it was running rich too. ill bump you.
Old Dec 22, 2007 | 12:40 PM
No cat(s) = fuel smell
Did the problem start suddenly, or build up over a period of time? Did you make any changes just before it started smelling bad and bogging? When does it smell... at idle, normal driving, black cloud at WOT???? When does it bog?
DirtyDaveW
Dec 1, 2016 05:37 PM
grabbem88
Feb 13, 2015 03:09 PM
Iamherefornow
Jan 26, 2015 04:57 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
