Temp, on the red... water gurgling
Old Sep 22, 2003 | 10:00 PM
  #16
NewbieWar's Avatar
Thx all, i think its running well now...
yea u read right no thermostat
everyone seems to think that it would have trouble getting hot with no thermo, not overheating...
Old Sep 23, 2003 | 01:16 AM
  #17
Spinner's Avatar
No thermo = engine runs cooler. The thermostat is just a valve that doesnt let coolant flow between engine and radiator until X degrees. No thermostat, bigger passage for coolant transfer (though that may make no difference because its sent by the water pump) and coolant ALWAYS flowing between engine and radiator.
Old Sep 23, 2003 | 01:26 AM
  #18
NewbieWar's Avatar
well then what is the heating problem?
  #19
turbo_Z's Avatar
i heard.. never personally tested this theory out if you wanna call it that. what i once read on here is that there needs to be a thermostat or the coolant doesnt circulate through the radiator i believe.. naturally youd overheat. the reverse-flow cooling systems work a little differently than people think.
Magenta_Hearts
Mar 29, 2017 08:54 PM
pimpen1024
Aug 19, 2015 08:36 PM
Biggiebound
Apr 23, 2015 08:50 AM
Biggiebound
Apr 21, 2015 11:28 PM
Hot Rod Hawk
Jul 18, 2002 03:08 PM
