temp. questions
Old Jun 24, 2004 | 03:20 PM
Chiappj's Avatar
temp. questions
hello, I have a 1996 SS camaro and maybe 5 months ago the water pump went out and I had that replaced. (did not replace thermostat) and ever since than it has been running right ni the middle of the temp guage.. somtiems a lil above the half way mark. Before the water pump was done the car ran 160 - 180. My mechanic said no way they never run that low.
So my question is what temp is normal? and if im high how do i fix this problem. If it helps my electric fan comes on but never really cools the engine off... and sometimes it blows hot air other times cold. thank you for your help i REALLY appreciate it.
Old Jun 24, 2004 | 04:04 PM
Ricardo's Avatar
If you have a stock tune in your PCM the fans should come in at 226 deg and the second stage at 234 deg.
Old Jun 24, 2004 | 04:12 PM
Could be that your old w/p had a 160° thermostat in it and when you replaced the pump, it might have come with a 180° (new GM pumps come with a 180° installed).
Old Jun 24, 2004 | 06:16 PM
Chiappj's Avatar
sorry i'm still learning about cars (i work at dealership though) when i watched the mechanic do it i dont think he flushed the radiaotor. could anyone lead me to a good site that expalins how to bleed/flush the system?
and shoebox, i dont believe the thermostat was replaced
thanks for your help!
... and again what is the normal temp???
Old Jun 24, 2004 | 07:40 PM
Normal running temp with stock thermostat will be ~195°. It will go up to 226° when you sit in traffic until the fans come on. That's about the middle of the gauge.
Old Jun 24, 2004 | 07:47 PM
Chiappj's Avatar
THANK YOU!!
would you happen to know a sight that tells yo how to flush/bleed the sytem... i cant seem to find anything
Old Jun 24, 2004 | 07:51 PM
Originally posted by Chiappj
THANK YOU!!
There is a drain and refill procdure on my Tech Page.
HCz28
Feb 15, 2015 03:01 PM
spearous
Jan 12, 2015 11:03 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
brentbrowning01
Dec 16, 2014 06:35 AM
Hurin
Dec 13, 2014 07:38 PM
