Tell me about Installed Spring height
Old Feb 13, 2007 | 11:32 PM
Bow94z's Avatar
Yea Installed height is the only thing im still confused on on my LT4springs /1.6 rocker swap.
any info would be greatful
Old Feb 14, 2007 | 12:06 AM
SS RRR's Avatar
This may help you out...
http://cranecams.com/?show=valveSpringRate
Old Feb 14, 2007 | 12:35 AM
sidney004's Avatar
I recently did this very same change. We measured one spring and it was per spec. Installed everything without shims or measurements along with new 7.200 pushrods; everthing worked perfectly.
Old Feb 14, 2007 | 10:31 AM
Bow94z's Avatar
Originally Posted by SS RRR
great, just what i was lookin for
Old Feb 14, 2007 | 02:50 PM
ayers1967's Avatar
The Installed valve height is what it is .you check it so you know what the measurement is so you can set it up on a spring compressor and see what seat pressure is. and then measure max lift on your cam to see if you have coil bind .With the GM hot cam i had to use 0.50 offset locks to keep it out of coil bind.
Old Feb 14, 2007 | 03:09 PM
rskrause's Avatar
Moderator
In a high power buildup one of the many factors to try to optimize is cylinder to cylinder variation - optimum is none, i.e. they need to be as close as possible. Accordingly, the "right" way to set up heads is to check each spring and set the installed height to the desired value. On a less than all out motor, this isn't necessary - but I do it every time.
Rich
Old Feb 15, 2007 | 11:13 AM
Bow94z's Avatar
so when i swap out my stock springs, i could get away with measuring one and just go ahead and install the LT4's from there...
With this swap do i need to even measure? I thought you just compress the old ones, swap them out with the new ones, and lock em in and ur done with this swap
Old Feb 15, 2007 | 11:33 AM
BlackScreaminMachine's Avatar
Also to be mentioned when you run cams that are near the max lift of the spring, its considered required since there is little room for error.
Old Feb 15, 2007 | 07:21 PM
sidney004's Avatar
With a stock cam and stock head, which is exactly what I had; you should be able to swap springs and just bolt everything. It should work fine. It has worked for me...so far.
Carogna'sZ-28
Feb 3, 2015 07:04 PM
cmdeshon
Dec 12, 2014 10:51 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
MislMan
Jul 19, 2002 11:41 AM
