tdc and cam install
Old Jul 7, 2004 | 11:39 PM
1badasZ's Avatar
Exclamation tdc and cam install
do i need to get the #1 piston all the way up before i take anything out?i already have the heads n lifters n stuff off. do i need to get it up before i take the timing chain off n cam out? this is my first time doing this and i just wanna make sure im doing things right. i dont have anyone to call to help so im in the dark on this. thanks in advance for any help
Old Jul 7, 2004 | 11:55 PM
Not necessary to put it in any position to get things out. You will line it up correctly when you install, though. Cam removal and install info can be found on my Tech Page.
Old Jul 7, 2004 | 11:57 PM
1racerdude's Avatar
Makes it a no brainer when you put it back together.A lot easier.It makes it quicker coming apart too you don't have to check to see what is or needs lining up"IT ALREADY IS"
Old Jul 8, 2004 | 01:00 AM
ss#1230's Avatar
listen to shoebox. he knows whats up. the little dots on the cam sprocket and crank sprocket line up when things go back in. youve just got to make sure the pistons are right when you adjust your rocker arms.
pm me if you need to know the sequence for adjusting the rockers. good luck. the job is intimidating but youll realize its not so bad when your done. i cant wait till i can get my new heads!!!
oh yeah, dont forget to have your PCM programmed! i was going to do it and shoebox gave me further incouragement to do so. i ended up having Ion at MadZ28.com program mine and boy i tell you!!! it really makes that cam come to life! ive got to recommend him for the job....especially for only 125 bucks!!! and hes very quick at getting it programmed and returned.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
smokin5s
Jul 24, 2003 10:47 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
