TCC wire hook-up
Old Dec 18, 2010 | 02:35 PM
gearhead90's Avatar
TCC wire hook-up
im having problems locating where the TCC wire plugs into....im starting to get really frustrated with this car because i get get good answers from anyone about anything when i need a little help so could someone please point me in the right direction on where this wire plugs into?
Old Dec 18, 2010 | 02:44 PM
RamAir95TA's Avatar
Re: TCC wire hook-up
What are you trying to do? Wire up a lock-up switch?
The wire is located in the blue PCM connector (D), pin D6, and it's a brown wire. Grounding the wire out will engage the TCC solenoid.
Old Dec 18, 2010 | 02:50 PM
gearhead90's Avatar
i just got done rebuilding my LT1 and its my first engine rebuild and theres a connector i found that i traced through the schematics with and found out it was the TCC connector for the solenoid...i just dont know where it plugs in...im already having issues with the dam thing...cant even get the thing to start it just keeps cranking.
Old Dec 18, 2010 | 03:05 PM
Since there are differences from year to year, it would be to your advantage to add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. Makes it easier for people to help you.
Which end of the wire are you trying to hook up.... PCM or at the trans?
Look at this wiring diagram, from Shoebox. Depending on the year, yours may be different = 94 is on/off, 95 and up is pulse width modulated.
http://shbox.com/1/1995_pcm7.jpg
Old Dec 18, 2010 | 03:10 PM
gearhead90's Avatar
the trans end...mines as a 94 z28
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
kandied91z
Aug 6, 2002 01:18 AM
