TB Bypass-Not the same question ask
Old Feb 28, 2004 | 11:21 AM
zoso1959's Avatar
Question TB Bypass-Not the same question ask
I wanted to know if i will gain anything from doing this.
I have a 160 stat and the fans are program to come on at 180 & 185.
the coolant will run cooler thru the throttle body.
i'm looking for good solid answers not just opinions...............
thanks guys
zoso
Old Feb 28, 2004 | 11:42 AM
teke184's Avatar
YES
a cooler air charge is a denser charge...which makes more power.
the thing is you will not notice it...only a couple hp ...but it's cheap and easy
Old Feb 29, 2004 | 12:15 PM
zoso1959's Avatar
Unhappy update on tb bypass
Well I tried and i couldn't get the drivers side hose off unless i where to cut it.
but before i were to do that i wanted to make sure i could get the passenger side,
that has 2 of those hose clamps,
after removing the upper throttle body tube and a few plug in sesors and the
alt. bracket i had no access to get to those clips, they where both on the bottom of the hose
so instead of taking a chance and being able to cut 1 hose off, i put her back together and will take her to a speed shop
to have them do it, i just can't take the chance of the car not running, she is my daily drive .
thanks for all your help.
tony
Old Feb 29, 2004 | 12:19 PM
raceryan's Avatar
If you can change an oil filter, you should be able to this yourself in about 2 1/2 min.
Old Feb 29, 2004 | 12:37 PM
zoso1959's Avatar
i got everything apart just couldn't get the hose clamps on the passenger side to release the hose, its a b****
tony
Old Feb 29, 2004 | 12:44 PM
Spinner's Avatar
tony
So cut it. Wont make a difference
Old Feb 29, 2004 | 12:48 PM
zoso1959's Avatar
i don't have a problem cutting the hoses, but the hose by the stem tube the clamp is on the bottom of that hose and even with everything remove i can't get down there to sqeeze the clamp off to remove from th stem tube
thats my problem.................
Old Feb 29, 2004 | 01:13 PM
raceryan's Avatar
Try to break the clamp with pliers or cut with wire cutters. You'll still have plenty of hose left if you hack it off a half inch before the throttle body.
Old Feb 29, 2004 | 01:19 PM
zoso1959's Avatar
thanks...................
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
