Tb Bypass
Old Jan 3, 2007 | 05:21 PM
95 WHITE TRANS's Avatar
Tb Bypass
Hi .I would like to know when i do the tb bypass. Do i have to bleed the radiator system.
95 trans am
THANK YOU
Old Jan 3, 2007 | 06:01 PM
micfly83's Avatar
No.
At least I didnt have to.
Just let the engine sit for a bit so it can lose some pressure and so its not scalding hot (mistake I made ).
Be ready for a good bit of coolant to come out
and PROTECT THAT OPTI
Here you go http://shbox.com/1/tb_bypass.jpg
Old Jan 3, 2007 | 06:33 PM
lt1redneck's Avatar
Yes PROTECT THE OPTI i made that mistake now its costing me. I feel like an idiot. hell a $2 mod is now costing me 400 bucks just in parts.
Old Jan 3, 2007 | 06:58 PM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
i didn't bleed mine but i sure protected the opti. i bet i had enough rags in there to catch a full radiators worth of fluid.
David
Old Jan 4, 2007 | 12:02 PM
2000GTP's Avatar
I never bled my system either, but as mentioned above, the protection of your optispark(distributor) is very important. That goes for replacing the water pump or thermostat as well which involves the risk of coolant soaking the opti.
Old Jan 4, 2007 | 12:32 PM
Maybe some confusing terms being used. To protect the Opti from a coolant bath, drain the radiator below the TB coolant connection level. After you have the hoses reconnected to each other, fill the radiator back up and bleed the air out of the cooling system.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
