can someone tell me what's wrong? Datalog inside....
well i finally got around to buying a cable to datalog, and got a file recorded. I replaced the pcv valve and took off the breather on the pass. side valvecover, now everything should be working but the car runs like ****. compared to when i had the breather and plugged vacuum line and pcv valve the car is running very horrible. only thing is how can i post the tts datamaster file on here? or should i email it to someone to take a look?
i noticed that the knock count in open loop(166) and then closed loop it was like 33k. i dont know what the hell it might be except for maybe the exhaust leaks at the collectors or maybe a rocker is loose which i doubt because id prolly hear it. on a WOT run i noticed that the injector duty cycle went to like 99% which might explain my car going lean on the top end sometimes. i really need some help guys and any feed back is appreciated.
You need to find an FTP site that you can upload the file to. If you upload it in .uni format, only people with DataMaster will be able to look at your file. If you upload it in .csv format ("export" option in DataMaster) any can look at it with Excel.
i changed it over to .csv format and opened it on excel but since i just purchased the laptop i need to purchase the product software to view the file. i can email it to someone if you guys can take a look at it for me.
here's the .uni file
http://www.freefileupload.net/file.p...02970/run1.uni
and here's the .csv file, dont know if i converted it properly
http://www.freefileupload.net/file.p...393/Run1.2.csv
hope this helps, please let me know what's wrong with the car!
i was trying to go through the Computer forums and tried a search but i get a 404 forbidden access message. cant figure out why, but does anyone have the same problem. off topic but i've been trying to find a site but to no avail. i can email it to anyone that wants to take a look at it.
i tried to upload it to some other sites but they didnt work either. so i uploaded it to the same website. here it is:
http://www.freefileupload.net/file.p...38429/run1.uni
Aaront810
Aug 29, 2020 09:34 PM
