tb bypass
Old Nov 28, 2006 | 07:55 AM
  #16
Sweetred95ta's Avatar
Originally Posted by RacingTiger04
just out of curiosity.. everything i find on the tb bypass links me back to that pick from shoebox, but the picture says 95-97. Is this mod different on the 94 model? ive been considering getting around to it for some time, but this always leads me back astray from it.
I'm pretty sure it's similar, if not the same. It's pretty self-explanatory. Just take the coolant hose going into the tb and the coolant hose coming out of the tb and connect them.
Old Nov 28, 2006 | 10:34 AM
  #17
Originally Posted by camarolt4ss
as well couldnt i get a new piece of hose, and just run it that way, instead of connecting it?
Why not add a "signature" with basic info about your car - year, model, tranny and any major mods. In this case, what year your car is determines what you need to do to make the bypass work.
Originally Posted by onebad636
You don't even need another peice of hose. All you need to do is take the hose off of the right side of the TB and take the one off of the left side of the TB and put the right side one on the metal line that runs to the back of the intake. Then just put some rubber caps on your water lines on the TB. That's it!
Depends on th year of his car, wich he has not included in his post. 93/94 requires a short 3/8" barbed hose connector to put the two hoses together. 95-97 can can done as you have described.
See above response... 93/94 are different than 95-97.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
