tb bypass
Old Apr 8, 2003 | 06:40 PM
Andy W.'s Avatar
tb bypass
have 93 z and have seen about tb bypass and was wanting to know what kind of gains are we talking about, and how do you go about doing it, help please.
Old Apr 8, 2003 | 07:24 PM
94F1Z28's Avatar
Well the gains are small but they are pretty much free.You will gain between 5-8 rwhp.It is easy to do just take the two lines going into and from the TB and use a pipe and clamp them together so the coolant no longer flows through the TB , also be careful not to leak any coolant onto your opti.
Old Apr 8, 2003 | 07:44 PM
Kris93/95Z28's Avatar
It is very simple like was stated above, just cap the lines with some 1/4" vaccuum caps
heres a good write up:
http://www.geocities.com/MotorCity/6647/ta93/tbody.htm
http://www.geocities.com/MotorCity/T.../tbbypass.html
Make sure to bleed the system afterwards
Old Apr 8, 2003 | 07:52 PM
ImportsRsloths's Avatar
Here is a good dyno run Before/After of the TB Bypass..... And some pics of a beautiful car!!!
Old Apr 8, 2003 | 08:07 PM
magnumv8's Avatar
COVER YOUR OPTI
coolant on opti =
Old Apr 8, 2003 | 08:35 PM
BOWTYDE's Avatar
Have you personaly seen 5-8 Rear?? I didn't realize that TB helped that much.
Old Apr 8, 2003 | 09:44 PM
burnemonm1's Avatar
do u really need to cap the holes on the tb???
Old Apr 8, 2003 | 09:50 PM
Keith's WS6.COM TB Bypass dyno
Not "necessary" to cap the connections on the TB, but it sure looks nicer if you at least cap the one thats visible on the drivers side.
Old Apr 8, 2003 | 10:30 PM
BOWTYDE's Avatar
WOW
I know what I'm going to do now.
Thanks.
Old Apr 9, 2003 | 05:25 PM
Andy W.'s Avatar
thanks guys
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
