tb and bigger injectors on a cc306 + all bolt ons, is it worth it?
I don't know if injectors are made with a minimum pulse width, but no matter what an injectors flow is, you can tune the pulse width to only deliver a certain amount of fuel so I don't see the problem. Obviously you don't want to go overboard with a 160# injector, but I don't see a problem with using a 36-42# injector as long as it's tuned right. Is there such a thing as too big a fuel pump? No, because the regulator is set to give you what you need same as the tune regulates your injector.
i know if i buy injectors i would need to look towards the future and with that said i would like to end up with a le2 and a 100 shot. so with this in mind i would think i would need at least 42lbs for that and if it would work with my current set up i think it would be my best option. would this work?
You need to do alot of research and listen to people who have done all of this before. 42lb injectors and a 58mm tb....is way overkill
I know people that have made 400 plus with the stock injectors and stock TB. Its not streetable so a 52 and 30's would probly get you where you need to be....all of it can be tuned to work but it won't be optimal, I see these same questions asked over and over everyday and people seem to still make the same mistakes over and over. All the biggest parts are not going to make you fast...Its all about everything working together
Bignasty85
Mar 3, 2015 04:05 PM
Joe Brodman
Jul 24, 2002 05:24 AM
