Will LCA's help me?
Old Aug 12, 2002 | 09:50 PM
96z's Avatar
96z
Post Will LCA's help me?
Currently my best time at the track was a 12.7 at 108, my 60' was 1.85 with nittos. I have to launch easily or I just spin and the rear end flys out to the right. Besides subframes and a strut tower brace the suspension is stock. Will LCA's help me at all? Are they worth it over relocation brackets?
Experiences please.
96 black Z28 A4
GTP heads, GTP cam, bolt ons...
Mattucci Motorsports WNYFA FLFB
So far...12.7@108...need more practice...
The Z
Old Aug 14, 2002 | 05:17 PM
V6toZ28's Avatar
Post
LCAs wouldn't hurt, as well as some stiffer shocks in the rear. KYB AGX are realtively inexpensive - less than a $100 each from Summit. You can stiffen them up for the track and adjust them down for a pretty comfortable ride on the street.
But I would say your biggest issue is tires. Nitto's are OK for a mostly stock set up. But, with H/C you're probably laying enough power down to overwhelm them. It's time to step up to set of ET Streets or Hoosier QTPs for the track.
Good Luck
'01 Mystic Teal Z28
A4/3.73
Mods List Here
12.12/112.81/1.70 60'
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
"To play it safe is not to play"
Old Aug 14, 2002 | 09:41 PM
96z's Avatar
96z
Post
Yeah, ET streets are defenitly next...
Are the reloc. brakets better than LCAs?
96 black Z28 A4
The Z
Old Aug 15, 2002 | 11:06 AM
CANTONRACER's Avatar
Post
LCA's and SFC's helped me very much. Other than my sway bar removal, that is all I have done to my suspension and cut 1.6X every time.
1996 Z28 Camaro
2001 best 1/4 BFG DR's NA - 11.865@113.57 w/1.634 60', 1/8 - 7.563@89.82mph Best 1/4 MPH 114.82 - Best 1/8 MPH 90.73 - 2002 Mid 11's NA, Mid 10's n2o
1989 GMC 1500 truck for work 18.1@73 305
8 cats to feed clean after 1999 V6 Mustang 5 speed
15.358@89.47 MPH w/ 2.227 60'
15.364@90.92 MPH w/ 2.383 60'
My Z28
Old Aug 15, 2002 | 12:06 PM
96z's Avatar
96z
Post
Thanks for the info Canton Racer.
Looks like Ill get the LCAs and some ET Streets than.
96 black Z28 A4
The Z
Old Aug 17, 2002 | 09:29 PM
SAR2K's Avatar
Arrow
I've had major traction issues since I jumped to a larger converter. Wheel hop & spin big time. I already has G2 LCAs and figured a set of HALs in the back would get rid of the hop & spin. Well the HALs cured the hop, but I was still spinning to upper 1.6 60' times. I just installed a set of BMR bolt-on relocation brackes and the difference is huge on the street. Unfortunately I just toasted the transmission so I'll have to wait a week to see what it does at the strip. Judging by the way it did on the street, I'm sure my traction issues at the track are history with the brackets.
Steve...
1996 TA
12.53; 106.97; 1.65-60'
A4, Ram-Air, Damn near every bolt on...
2001 CBR600F4i Pearl White/Red
2002 Cavalier no times
[This message has been edited by SAR2K (edited August 17, 2002).]
96SilverRam
Nov 20, 2016 11:19 AM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Boss002
Jul 24, 2015 10:47 AM
