Taylor wires for Hooker LT's, top loom or side loom?
Old Mar 17, 2004 | 09:47 PM
  #16
canbaufo's Avatar
Originally posted by parkerz28
If it helps I'm about to do a sparkplug/wire change. I'm probably will be going with MSD's 8.5mm superconductors.
Those are the ones I was thinking of, they would be $58 or so and the made for you looms are a click over $40 ....about the same as a Taylor kit. If the taylor wires would suffice that would sure simplify things though. Has anyone else had bad luck with the Taylor wires arcing besides the one poster?
Old Mar 17, 2004 | 09:51 PM
  #17
CamaroBoy96Z28's Avatar
I've been running Taylors with my Jet-Hot LTs since the end of June and have had zero problems. I have pics of mine in the sig.
Old Mar 17, 2004 | 10:09 PM
  #18
LilJayV10's Avatar
I personally think the taylors are junk. I have installed them on two cars and never will again. the MSD wires are alot better. just my .02
Jason
Old Mar 17, 2004 | 10:13 PM
  #19
canbaufo's Avatar
Keep the opinions coming. I need the best set I can get because it's a major, major PITA to change them in my case because it requires removal of the supercharger head unit.
Old Mar 17, 2004 | 10:50 PM
  #20
LS1_03's Avatar
I suggest the top loom. I just did a long tube swap 2 weekends ago on my car. I went with the top looms. It looks great, it's clean looking, the wires are no where near the primaries. I've had zero problems with the taylor wires. I'm pretty happy with it.
Old Mar 20, 2004 | 06:45 AM
  #21
parkerz28's Avatar
Where do you see them for $58 dollars for the mds's? Let me know! The cheapest I saw was at summit for 75.
-Oh and doing research myself, I plan on staying away from Taylor. I've read no negatives on the MSD's.
Old Mar 20, 2004 | 08:27 AM
  #22
joeSS97's Avatar
I am happy with the Taylors over the top.I would buy them again.They look great too.
Old Mar 20, 2004 | 01:12 PM
  #23
Achilles97's Avatar
I've had zero problems with my Taylor wires. There is absolutely no arcing. The kit from Thunderracing also comes with a wire crimper and the correct boots (straight, not bent).
Old Mar 20, 2004 | 02:13 PM
  #24
ibanez6rg's Avatar
I have over the top looms, I really don't like the side (based on looks). I'm running Taylor wires and haven't had any problems with them.
Old Mar 20, 2004 | 04:07 PM
  #25
3()thZ's Avatar
wires
Bro the wires you want are the msd-32139 available from summit. You can also get the madeforyou's from summit too. Very nice set up
Old Mar 20, 2004 | 05:28 PM
  #26
BPS's Avatar
BPS
I'm using these side looms
http://store.summitracing.com/partde...=MG&part=25168
alond with the msd 32129 universal wires
Old Mar 21, 2004 | 01:45 PM
  #27
canbaufo's Avatar
OK, you all have given me two different PN's for the MSD's (32129 vs 32139) ....what's the difference? As long as the MSD's are straight boot style for the opti I think I'd rather go with them than the Taylors. Are these 8.0, 8.5 or what? I think top loom is the way to go. Thanks for all of the info.
Old Mar 21, 2004 | 03:02 PM
  #28
BPS's Avatar
BPS
32129 MSN 8.5mm universal lt1 - straight boot (f Body)
32139 MSd 8.5mm universal LT1 - 90 degree boot (Impala)
Old Mar 21, 2004 | 04:03 PM
  #29
canbaufo's Avatar
Thumbs up
Thanks Bill, I can always count on you for accurate information. My decision is now made on wires. Now for the decision on looms. Why did you go with the side loom over the top loom Bill? If you had it to do over again would you stick with the side loom or do you think the Made For You Centerbolts would be better?
Old Mar 21, 2004 | 05:15 PM
  #30
BPS's Avatar
BPS
I've installed lt4 composite valve covers as the top looms do not work as well as side ones do.
The looms I purchased still get bolted through the top of the valve cover but I can addredd the issue with a couple of washers.
had it not been frot that I'd likely have gone with the made for you looms on the top of the valve cover.
However my solution is cheaper and looks very sturdy.
I prefer the msd universal set over thee taylors as you fit the spark plug boot and not the opti boot - so I think measuring and stuff is easier.
Note the thicker diameter of the MSD wires require some modification (drilling) of the MFY looms which have a dimeter of 8mm
