Taylor wires for Hooker LT's, top loom or side loom?
Originally posted by parkerz28
If it helps I'm about to do a sparkplug/wire change. I'm probably will be going with MSD's 8.5mm superconductors.
Keep the opinions coming. I need the best set I can get because it's a major, major PITA to change them in my case because it requires removal of the supercharger head unit.
I suggest the top loom. I just did a long tube swap 2 weekends ago on my car. I went with the top looms. It looks great, it's clean looking, the wires are no where near the primaries. I've had zero problems with the taylor wires. I'm pretty happy with it.
Originally posted by canbaufo
Those are the ones I was thinking of, they would be $58 or so and the made for you looms are a click over $40 ....about the same as a Taylor kit. If the taylor wires would suffice that would sure simplify things though. Has anyone else had bad luck with the Taylor wires arcing besides the one poster?
-Oh and doing research myself, I plan on staying away from Taylor. I've read no negatives on the MSD's.
I'm using these side looms
http://store.summitracing.com/partde...=MG&part=25168
alond with the msd 32129 universal wires
32129 MSN 8.5mm universal lt1 - straight boot (f Body)
32139 MSd 8.5mm universal LT1 - 90 degree boot (Impala)
I've installed lt4 composite valve covers as the top looms do not work as well as side ones do.
The looms I purchased still get bolted through the top of the valve cover but I can addredd the issue with a couple of washers.
had it not been frot that I'd likely have gone with the made for you looms on the top of the valve cover.
However my solution is cheaper and looks very sturdy.
I prefer the msd universal set over thee taylors as you fit the spark plug boot and not the opti boot - so I think measuring and stuff is easier.
Note the thicker diameter of the MSD wires require some modification (drilling) of the MFY looms which have a dimeter of 8mm
