Taller vavle cover AND no modifications?
Old Sep 15, 2008 | 07:11 PM
ss.slp.ls1's Avatar
Okay, I tried searching with no real clear answers...
I want to find a set of valve covers (for a 95 Z28) that add the most clearance AND require no modification whatsoever. Thanks for the help.
Old Sep 15, 2008 | 07:17 PM
No modification for what? Alternator clearance.......
Old Sep 15, 2008 | 07:23 PM
ss.slp.ls1's Avatar
Yeah, no clearancing needed to clear the rockers (not a huge cam) or to clear the alternator (will not be relocating). Thanks.
Old Sep 16, 2008 | 09:38 PM
lt1-xjs's Avatar
I doubt you'll find any but the Proforms work and look good. It takes about 10 minutes to notch the alt. Very simple. I run the 141-131.
Old Sep 17, 2008 | 09:06 AM
ss.slp.ls1's Avatar
Someone else mentioned that part # on a different forum as well. How do you notch the alt?
Old Sep 17, 2008 | 01:08 PM
87bandit's Avatar
http://www.lt1engine.com/tech/how-to...-valve-covers/
Old Sep 17, 2008 | 05:36 PM
ss.slp.ls1's Avatar
I also read that Cantons were good pieces, but I read that they have sealing problems and clearance issues. Do how do the proforms compare as far as any clearance issue or leaking issues?
Old Sep 17, 2008 | 08:43 PM
lt1-xjs's Avatar
I've not had any issues, been through 3 rocker changes and a few adjustments and still use the same gasket. (1.52 Promag,1.6 Promag and
1.7 Scorpion)
Old Sep 17, 2008 | 10:38 PM
96' Formula WS6's Avatar
where's the best place to get cantons. Any vendors sell it.
Old Sep 18, 2008 | 12:08 AM
mad95z's Avatar
I love the look of my Canton valve covers. No leaks.
I had to "massage" them with a hammer where the alternator notch is to fit over my 1.6 comp pro mags. Also had to grind the alt, to make it sit in place.
You cannot fully attach the alt bracket that mounts on the intake, but the alt holds very steady. You also have to pull the alt to remove the passenger side valve cover, PITA! O yeah you may have to bend the trand fluid dipstick out of the way also.
But they look great, have had many complements.
Got mine from E-BAY
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Ken Cemo
May 16, 2015 05:03 PM
Apr 3, 2015 10:54 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ReznorZ28
Aug 27, 2002 03:53 PM
