Taller Tires on the Back?
Old Jun 8, 2003 | 10:22 AM
MikeW's Avatar
Hi everyone, I am a long time reader here but have never posted. I have a question and have searched the forum without getting a straight answer.
The car in question is my dad's 95 6-speed Camaro. He has bought some 17" rims and wants to put a slightly taller/wider tire on the back (285/40 vs. 275/40). Can he do this without causing ABS/TCS problems?
Thanks for your help.
Old Jun 8, 2003 | 11:34 AM
grendal's Avatar
I doubt it will make any difference at all, nor will it look any different, nor will it make any difference in traction. I can't imagine why he'd bother.
-Michael
Old Jun 8, 2003 | 11:37 AM
Check the tire specs in regard to diameter of the two tires. I doubt there is enough difference to bother the ABS/TCS.
Old Jun 8, 2003 | 11:48 AM
MikeW's Avatar
Thanks for the replies guys.
I told him the same thing, I don't understand what the appeal is. He has slicks for the track anyway! But it's his car, and his choice I guess.
As for the differences in diameter, it will be 25.6" vs. 26.0". I have always assumed GM makes some allowence for different heights, like if you had decently-worn tires on the front and brand new ones on the back, the question is how much is the allowence?
Old Jun 9, 2003 | 08:09 PM
MikeW's Avatar
Just wanted to bring this back toward the front, a lot of people probably don't come here on the weekend.
Anyone?
After this, I'll let it die. Promise.
Old Jun 9, 2003 | 09:09 PM
rskrause's Avatar
Moderator
Most 285's have considerably wider tread than the same brand 275's. With the BFG's I am using, the 285 has nearly more than 1/2 inch more tread width. The 285/275 combo makes sense to me, that's why I use it. The 285 will put the speedo off by a few percent unless the PCM is reprogrammed. There will be no problem with ABS though.
Rich Krause
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ModdedNerd
Dec 25, 2014 05:51 PM
Hurin
Dec 13, 2014 07:38 PM
Snoman73
Nov 17, 2014 07:22 PM
formula79
72
Jun 29, 2002 08:18 PM
